Old 02-13-2015, 11:24 AM   #1
Nahtorious
Drives: 2007 Yaris Sedan
Windshield washer sprayer problems
What up guys,
My windshield washer sprayer shoots so damn low on my window, they honestly spray just above my wipers. is there any way to adjust it or replace them?
Thanks.
Nahtorious is offline   Reply With Quote
Old 02-13-2015, 12:35 PM   #2
nortonfb
Drives: 2007
Use a pin or similar. Insert in nozzle and re-aim.
Norton
nortonfb is offline   Reply With Quote
Old 02-13-2015, 12:59 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
You can't reaim the Yaris nozzle can you?
Old 02-13-2015, 01:15 PM   #4
Nahtorious
I tried, didn't seem to want to move.
Old 02-13-2015, 03:24 PM   #5
They are fixed and cannot be adjusted.
Old 02-13-2015, 03:39 PM   #6
Nahtorious
If I buy new ones for like 15 bucks, are they easy to swap?
Old 02-13-2015, 05:08 PM   #7
bronsin
bronsin's Avatar
Try to re aim like Norton proposes. There is a tiny ball which rotates in a socket thru which the water comes out. A common pin placed in the tiny hole can rotate the ball in the socket thus directing the stream.
At least every other car I owned had that.
Old 02-13-2015, 05:11 PM   #8
bronsin
bronsin's Avatar
Alas I see there is no ball just a square hole.
How is the stream normal or weak. Perhaps your pump is bad or a line kinked?
Old 02-13-2015, 05:14 PM   #9
Nahtorious
It's strong... Just aimed in a stupid spot. So frustrating especially when I'm driving... The wind just pushes it down further.
Old 02-13-2015, 05:19 PM   #10
nortonfb
Drives: 2007
I moved mine using a finishing nail.
My car is an 07 3 dr.
Maybe there is some crud in there.
Norton
Old 02-13-2015, 05:26 PM   #11
Nahtorious
Ok. I'll give it another shot. If it goes, great.. If it breaks, I'll be back to ask you guys how to change them. Lol.
Old 02-13-2015, 06:50 PM   #12
IllusionX
It's cold these days. The pump tend to not pump as well when it's cold.
Mine shoots stupid low in the winter. In the summer it's perfectly fine.
I think there is a TBS to change the nozzle on the hatchback because some early models shoot too low.
Old 02-13-2015, 06:53 PM   #13
Nahtorious
Mines the same all year man.
Old 02-14-2015, 06:42 AM   #14
IllusionX
Video?
Btw, I find it work best when the car is still.
While driving, it never shoots high enough.
Old 02-14-2015, 11:47 AM   #15
bairjo
It is indeed a good idea this Valentines day to make sure your nozzle is aimed properly. Otherwise someone will stick a pin in the tiny hole.
bairjo is offline   Reply With Quote
Old 02-16-2015, 08:44 AM   #16
IllusionX
Here is mine in action at -17c
http://www.youtube.com/watch?v=R3zgJ-re5d0
Old 02-16-2015, 08:47 AM   #17
Nahtorious
Yup! That's mine too
Old 02-16-2015, 08:48 AM   #18
Nahtorious
But mine looks like that all year round.
Removing Windshield Washer AGlobalThreat Fuel Economy Forum 14 05-02-2011 07:27 PM
Windshield washer fluid Twistoffate0817 General Yaris / Vitz Discussion 5 05-12-2010 12:47 PM
Windshield Washer indicater always on mlaverdiere General Yaris / Vitz Discussion 3 01-17-2010 02:43 PM
Windshield Washer Indicator captainm27 General Yaris / Vitz Discussion 25 01-21-2009 07:26 PM
New TSB Bulletin For Windshield Washer Sprayer Yaris General Yaris / Vitz Discussion 14 06-01-2007 01:47 PM
