#19 |
Is it? So the echo used the c150? Lol I haven't touched this in years. My old memory is failing me. :)
#20 |
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
Correct! C150 are the Echos 6 bolts
R-CaT Project Yar 2ZR |
#21 | |
2ZR swap. DO IT! Ask how!
#22 |
HacKers WanTed!
Cranky car feels great! Still breaking in th clutch but the change of 1st to 2nd and 3rd to 4th is noticible... 300 miles more to go on breakin love the Centerforce Dual Friction the pedal feel its almost ligher thar stock
#23 |
Excellent! Glad I could help. Now if we could just get that 2ZR swap DIY posted... =)
#24 |
![]() Drives: Yaris MK2 Join Date: Jan 2016
Sorry to pump up the old thread with a question about regearing the 5th on a Yaris.
I've searched the forum but couldn't find the part numbers for the gear set to bring it down to 0.725, just info but no parts number. I've got the C54 gearbox (according to vin and parts catalogue) on a 2006 1.3 hatchback (couldn't find the final drive ratio either unfortunately anywhere online), correct me if I'm wrong please but are the following part numbers correct for the 0.725 gearing 33428-12100 33036-12120 ? These seem to be from a 1ZZ engine corolla and should be a direct replacement ? Thanks |
#25 |
Yes, those are the correct part numbers. Look at Toyodiy.com for which models in your region have those parts. I did the same swap on my C50 build and the shaft journals (diameters) are the same for the 0.815 and 0.725 ratios.
#26 | |
One more question, you wouldn't happen to know what final drive ratio my car is on ? Or how I could figure that out (no mention in the manual, parts catalogue, on the casing whatsoever..) ? Thanks |
#27 |
You're welcome! You may be able to find the part numbers for the ring gear/pinion shaft on toyodiy.com as well if you put in your VIN/plate number. Post them here and I'll see if I can figure it out from that info.
#28 |
These show up according to VIN :
FRONT DIFFERENTIAL RING GEAR : 41221-12320 FRONT DIFFERENTIAL PINION : 41341-12030 FRONT DIFFERENTIAL SIDE GEAR : 41331-12011 FRONT DIFFERENTIAL PINION, NO.1 SHAFT : 41342-12140 Hope these are the numbers |
#29 |
That ring gear wasn't used in North America, so I can't confirm what ratio it was with my usual methods. I think you'd have to open the case and count the teeth to know for sure. Sorry I couldn't be more helpful.
#30 |
No worries, you have been a lot of help as it is thank you.
| Transmission teardown | CrankyOldMan | DIY / Maintenance / Service | 19 | 03-04-2015 10:31 PM |
| 5th gear messing up | N2scouting | DIY / Maintenance / Service | 1 | 09-07-2010 12:39 PM |
| longer 5th gear | german yaris | Performance Modifications | 36 | 11-06-2009 11:08 AM |
