Old 02-20-2015, 02:10 PM   #1
fbq262ken
Drives: Toyota Yaris (2004)
3rd Gear problems
I apologize if this topic or something similar is already posted.
I would like to ask if anybody else experienced this sensation: whenever I put the car on the 3rd gear, it is really a rough transmission. Often, in fact, I have to do it ultra slowly and with great care, or else it will stay neutral and do an awful noise (kind of like something stuck in your throat (the closest thing I can compare with)).
Important to note that this only happens on the 3rd gear, all the other gear seem unaffected by this problem.
My toyota yaris is the first edition, bought new in 2004.
fbq262ken is offline   Reply With Quote
Old 02-20-2015, 02:16 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
That would sound to me like either worn out syncros or most likely your 3rd gear itself has become very worn. When was the last time the transmission fluid was flushed and replaced? If this is the c50 transmission which I believe that it is then it is a somewhat of a known issue for the third gear wearing since it is your one to one ratio gear. Many times this will happen with people for 2nd gear as well however it all just depends on how hard the car is driven.
Old 02-20-2015, 02:51 PM   #3
fbq262ken
I believe the oil was never changed. It has 130,000km on the clock.
Old 02-20-2015, 03:27 PM   #4
fnkngrv
fnkngrv's Avatar
first thing you will want to do then anyway especially with the years of use and mileage is a flush and then moving to a synthetic trans fluid like AMSOIL, Redline, etc. You shoupd notice better shifting throughout.
Old 02-20-2015, 04:50 PM   #5
fbq262ken
I will keep you posted. Thanks mate!
Old 02-20-2015, 06:48 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've got the same issue in mine, but I just wrote it off as a side effect of having a short-throw shifter and an engine-bay short throw bracket. It feels like it's actually trying to go into third before second has correctly disengaged, but the shift pattern blocker on the gear select rod should prevent that...
Old 02-20-2015, 07:28 PM   #7
fbq262ken
It is very difficult to describe to be fair. All I know is it makes a nasty grinding noise. To get around this, I engage the third gear in a more gentle manner. Keep the clutch pressed down until I feel totally comfortable that it won't make that grinding noise. It really is effecting my driving as I am all the time wondering whether or not I need the third gear, and if so to painstakingly engage the third gear in a way to not grind.
Was in an accident due to this in fact as I lost a bit of concentration in engaging the gear, luckily there was absolutely no damage between the two cars.
Old 02-20-2015, 10:07 PM   #8
jcboy
Drives: Sedan 07
it is most likely a transmission part (collar/synchro, not to go into detail as im no expert).
but i echo the post above, it is best to start with the cheapest for now by changing gear oil and see if the problem goes away. (or probably check your shifter bushings or shift cable functionality, as i think the only other option left is rebuild transmission).
good luck!
Old 02-21-2015, 05:59 AM   #9
fbq262ken
What costs do you envisage I would incur to fix the problem?
Old 02-22-2015, 07:57 PM   #10
fbq262ken
Old 02-22-2015, 10:31 PM   #11
fnkngrv
fnkngrv's Avatar
where do you live? can you do any of it yourself?
Old 02-22-2015, 11:20 PM   #12
Supra_Yaris
Logan
Drives: 2009 Yaris Liftback Base MT
Mine does this exact same thing in second. Im about to flush the transmission fluid and us redline. Ill post results
Supra_Yaris is offline   Reply With Quote
Old 02-23-2015, 10:18 AM   #13
fbq262ken
Malta. I guest labour I am looking at about 20 euro....how much does a new synchromesh cost?
Old 02-23-2015, 10:18 AM   #14
fbq262ken
Cheers mate!
Old 02-23-2015, 11:21 AM   #15
CrankyOldMan
The synchro is the least expensive part of the repair--you have to drop the gearbox, open it, remove the 4th and 5th gears from the shaft, and then reassemble it. I would expect it to be no less than 8 hours labor to do that, assuming there are no other problems. It may be cheaper to just get a used gearbox and have the shop do a remove & replace instead.
Old 02-26-2015, 10:18 AM   #16
fbq262ken
Any updates mate?
Old 02-26-2015, 10:18 AM   #17
fbq262ken
Cheers man, I'll think it through then
3rd Gear grind hatchbackkid82 General Yaris / Vitz Discussion 92 02-15-2019 06:07 PM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 09:16 PM
yaris jerks a bit when shifting to 3rd gear. abdallah380 DIY / Maintenance / Service 3 09-19-2009 04:45 PM
Yaris seems to get stuck in 3rd gear when going uphill 47_MasoN_47 General Yaris / Vitz Discussion 16 08-24-2009 01:22 PM
2nd to 3rd gear shift (manual tranny) tekmoe General Yaris / Vitz Discussion 13 12-11-2006 07:27 PM
