Old 04-04-2012, 08:00 PM   #1
Strider199
Strider199's Avatar
Drives: Black 2012 Yaris 3door 5speed
Need to run 12 volt into compartment from battery
I've looked on the fire wall and I see a grommet but if I use that one then I will have to remove some of the dash. I tried pulling on the corner of the passenger side dash but it wouldn't give and I didn't want to break any of those tabs I read about. I want to hook up my CB radio to the battery directly. Has any one found an easy spot in the fire wall to do this? Also I plan on some extra front lighting and having a power source from the battery to the inside would be great.
New to the Toyota World, be nice.
Strider199 is offline   Reply With Quote
Old 04-04-2012, 09:00 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I punched a total of 3 holes so far through the firewall of my sedan and then installed my own grommets. I would recommend doing that. I am sure that there are others here with the LB that has done so too. You could search the DIY section especially for those that have done one for hooking up a stereo amp. You could also PM CTScott or he may chime in. He has an LB and has done extensive work with it.
Old 04-04-2012, 09:13 PM   #3
Strider199
Strider199's Avatar
Thanks fnkngrv. My hesitation is, the car is only a few months old and I am worried about having the warranty compromised. I used the large rubber grommets under the spare tire to run my CB antenna cable because I could always replace them for a couple of bucks but drilling a hole into the fire wall would not be that easy to repair should the dealership be looking for an excuse for some warranty work in the future.
If my car was out of warranty, I would not hesitate to drill for my convenience.
Old 04-04-2012, 09:43 PM   #4
fnkngrv
fnkngrv's Avatar
you can always put a plug in and I can just about guarantee that with a plug in a dealership would never know unless the specifically looked for it. did you wireloom your cable?
Old 04-04-2012, 10:22 PM   #5
Strider199
Strider199's Avatar
Thats a term (wireloom), that I will have to look up.
But just thinking out loud, No I didn't.
Old 04-04-2012, 10:23 PM   #6
J_Lynn
[Space For Rent]
J_Lynn's Avatar
Drives: 2010 LB
I had to punch a hole in my firewall for my subs when I hooked them up, I'm with Adrian - I recommend that .... and my car was about a week old when I did mine :) Toyota didn't notice and/or didn't care.
“With enough courage, you can do without a reputation.” Rhett Butler
J_Lynn is offline   Reply With Quote
Old 04-04-2012, 10:31 PM   #7
Right behind the battery is a giant grommet (~3" in diameter) for the main wiring harness. It has a lot of available space to punch through. I ran four #4 wires for my snowplow solenoid through it with room to spare. In the cabin it enters about a foot above the brake pedal.
Old 04-04-2012, 10:33 PM   #8
Strider199
Strider199's Avatar
Wire loom, a protective casing around the actual wire. My cable has a fantastic shield and protective covering which should do. No heat source close to the actual antenna cable.
Old 04-04-2012, 10:35 PM   #9
Strider199
Strider199's Avatar
Now thats what I wanted to hear.
Thanks CTScott. I will check it out this weekend.
Old 03-01-2015, 02:51 AM   #10
ucsmfu
Drives: yaris le
will I need to remove the battery to access to the giant grommet ?
thanks
ucsmfu is offline   Reply With Quote
Old 03-01-2015, 11:10 AM   #11
thanks
It is easier if you do, but if you feed something through the grommet from under the dash, you can typically find it under the hood, and then attach the wire to it and pull it back through.
Old 03-01-2015, 11:44 AM   #12
nortonfb
Drives: 2007
I had a terrible time trying to get something thru there.
A coat hanger with a bit of grease rubbed on it finally did it.
Takes a bit of twisting and cussing.
Norton
nortonfb is offline   Reply With Quote
Old 03-01-2015, 11:59 AM   #13
ucsmfu
Drives: yaris le
I looked everywhere yesterday and I couldn't find the location from under the hood ?
I found the grommet inside the cabin. It's above the brake pedal. But didn't locate anything under the hood ? Thanks
Old 03-01-2015, 12:28 PM   #14
You can't see it without removing the Wiper tray and battery. I use a 1/8" plastic rod to poke through and snake out. What tends to happen is that you poke through the grommet and then hit the back of the plastic piece that supports the Y on the harness, or you poke though and hit the back of the battery.
Old 03-01-2015, 01:44 PM   #15
ucsmfu
Drives: yaris le
Attachment 55039
thanks for the picture CTScott, so I'll have to poke a hole through the grommet ? not able to remove the grommet itself ?
Trying to feed the temperate probe wire through for the CIPA mirror install :/
Old 03-01-2015, 02:40 PM   #16
Correct - You will poke through it. To remove it (to cut a little slit and slide the probe wire in without shoving the probe through) would require pulling the wiper tray off to give you full access to it.
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 03:40 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 10:34 PM
Chevy Volt nemelek Off-topic / Other Cars / Everything else Discussions 8 04-03-2011 12:50 AM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 03:02 AM
