Old 11-15-2014, 09:59 PM   #19
Eduardo_mty
Ok... Let me try, Now...
Eduardo_mty is offline   Reply With Quote
Old 11-15-2014, 10:32 PM   #20
Eduardo_mty
I found it.. Thank you ctscott... I will "tap it" tomorrow
Old 11-16-2014, 01:03 AM   #21
ucsmfu
Drives: yaris le
let me know how it goes, I haven't installed mine yet.
ucsmfu is offline   Reply With Quote
Old 03-29-2015, 04:12 AM   #22
ucsmfu
Drives: yaris le
would the same reverse wire work in the 2012 Yaris ?
Old 03-29-2015, 08:54 AM   #23
yes
Old 03-29-2015, 03:00 PM   #24
ucsmfu
Drives: yaris le
yes
is there a connector where we can tap the reverse trigger wire in the back on the head unit ?
Don't want to extend the wire down all the way to ECU
Thanks CTScott.
Old 03-29-2015, 03:15 PM   #25
Thanks CTScott.
No
Old 03-31-2015, 02:23 PM   #26
ucsmfu
Drives: yaris le
You can grab the wire on the under dash fuse panel.
Connector 3C-33 or 3D-28
Attachment 54516
Attachment 54517
Hey Scott.
How do I confirm its the right wire to tap ?
I tested out the wires. Got 12 v when the car is turned on as well when the car is in reverse.
Thanks
Old 03-31-2015, 07:29 PM   #27
Hey Scott.
Thanks
Then you are on the wrong red wire. The correct red wire will only have 12 V when in reverse. I did double check and it is the same - 3C-33 or 3D-29.
Old 03-31-2015, 09:36 PM   #28
ucsmfu
Drives: yaris le
3C-33 or 3D 29 it's a yellow wire and a blue wire. The red wires are not in the correct 33 or 29 pin location, unless I am counting it wrong :/
Here's a picture.
Thanks
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 02:20 AM
Scion XD LED mirror install pics aplenty enviri DIY / Maintenance / Service 76 07-21-2019 03:10 PM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 09:53 PM
ANYONE know where to tap reverse wire for ntd? marcus Performance Modifications 10 11-23-2009 01:28 AM
Reverse Lights Wire Color? NateDogg In Car Entertainment + Electronics (audio / video / alarm) 0 02-01-2009 07:03 PM
