Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 04-19-2015, 03:45 PM   #1
JSCIII
Drives: Yaris Hatchback 3 Door USA Ver
Trunk Light Off
Hello folks!!
I'm new to this forum and this is my first post
I recently bought a Yaris 08 after a devastating crash with my 98 Corolla but unfortunately I've found a lot of stuff wrong my Yaris and now I need to start repairing one at a time
Anyways! I'm trying to fix the trunk light as I've changed the light bulb housing and the bulb itself without success, does anyone have a fuse box diagram for a 3dr vitz 08'? :) also if anyone has a full diagram of the connection between the bulb and the central system I'd appreciate it! So far I've checked if the computer detects if I open the door and it does, the problem is that it doesn't light up the trunk bulb 😕
Thank you!!
JSCIII is offline   Reply With Quote
Old 04-19-2015, 06:33 PM   #2
I have the wiring diagrams for the Vitz, but only in Japanese and on paper which makes it a bit more of a hassle.
For the trunk light though there is a switch within the latch that grounds the wire from the latch to the bulb to complete the connection when the trunk is open. If you have +12 on the other wire, then you need to check for continuity between the bulb's ground wire and chassis ground and work your way to the latch.
Old 04-21-2015, 07:55 AM   #3
JSCIII
You're on fire Scott �� I always see your name on different posts I've visited! It's awesome to have such a Yaris fan amongst us.
Ok so I'm checking the trunk wires and have an orange and a white cable, which one is the ground and which one is the bulbs ground? ��
HELP / Spoiler connecting light SimTronik DIY / Maintenance / Service 4 11-03-2010 12:08 AM
MAINT REQ'D light question... SAV912 General Yaris / Vitz Discussion 5 07-29-2010 01:20 AM
Charging System Light N9QGS DIY / Maintenance / Service 1 07-26-2010 07:53 PM
Plz help re: LED lights sleey0 DIY / Maintenance / Service 4 07-23-2010 10:55 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 02:26 AM
