![]() ![]() Drives: 2012 Yaris 5dr Hatch Join Date: Oct 2014
15mm Spacer Question
Will a 15mm spacer on the rear require me to shorten the stock lug nuts in order not to hit the back of the wheel?
Do you mean the spacers that come with their own studs and bolts to attach to the existing factory studs?
If so, most wheels have groves in the rear for the factory studs, if no grove you will have to trim facorty studs, order shorter studs, order longer studs and stand alone 15mm spacer, or dremel groves into the rear of the wheel (not recommended).
I ran 20mm spacers (H&R drm) and the factory studs stuck out past the 20mm spacer. |
![]() ![]() ![]() Drives: 2008 lowered yaris on 17's Join Date: Feb 2015
If you are talking about bolt on spacers, then the only way you could get away with not hitting the back of the wheel is if you had a wheel with the indentions on the rear of the wheel. if not our studs stick out about an inch so the smallest bolt on spacer that you could use without modification would have to be a 25mm spacer.
Following his other threads, it would appear he is still referring to this;
Basically the back of your wheel would have to look like this.
| For Sale: Project KICS 15mm spacer w/ hub center | enviri | Items for Sale by private party | 1 | 04-14-2014 07:42 AM |
| Best Rear Spacer | SeriousBlack | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 08-22-2011 02:44 AM |
| Wheel/hub spacer, PLS help | evo165 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 08-18-2009 02:21 AM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
