Old 05-04-2015, 09:24 PM   #1
"G"
Drives: 2007 Yaris Hatch
Exhaust smell in cabin
2007 sedan with 180k on it. Lately I've been getting exhaust gases coming in to the cabin at idle. I always have my fan on fresh air. Do you think it's just the gasket in between the mani & down pipe? I know there was a tsb on this but i'm way beyond the 80k warranty lol. I doubt it's the ex mani gasket since the mani has a brace so there should not be much flex.
"G" is offline   Reply With Quote
Old 05-04-2015, 09:55 PM   #2
The way your 2 flanges have been compressed together tells me that your gasket is totally shot. That is definitely your issue.
Old 05-04-2015, 10:44 PM   #3
"G"
Really? There is supposed to be a bigger gap?
Old 05-04-2015, 11:48 PM   #4
You have no gap. With an intact gasket in there you will have a gap of 3/16" or so. Also, the age and mileage of your car pretty much dictates the gasket is shot.
Old 05-05-2015, 12:08 AM   #5
tmontague
tmontague's Avatar
Yup, what Yari said. The gap you should see is created by the gasket filling in the space of the gap. Your gasket is so worn down that it's just metal to metal.
With how rusted those bolts are you should be replacing them anyways to make it easier to do down the road. Spray them with a penetrating oil every day for a week before you want to do them. I'd also buy a set of sockets for rounded bolts that was my saving grace to get my bolts out and I only have 139'000km on my Yaris. I think the sockets are called bolt outs.
Old 05-05-2015, 12:20 AM   #6
"G"
I hear ya. Looks like it'll be a fun job. Ordered up 2 new bolts, 2 springs & the gasket.
Old 05-06-2015, 09:05 PM   #7
"G"
New partz. 30% off list, looking for a source who has a more aggressive discount.
17451-21070 gasket $30.15
90501-a0005 spring $3.62
90080-10291 bolt $3.38
Old 05-06-2015, 09:49 PM   #8
IllusionX
Drives: 07 Yaris Sedan Aero
Sounds about right. Convert this to CAD and they are way too expensive!
Old 05-07-2015, 12:47 PM   #9
tmontague
tmontague's Avatar
Get them off of RockAuto.com much better deal. The bolts aren't exactly the same as oem but they work the same. You may have to file down the inside of the washer so it fits all the way onto the bolt like I had to, but the savings is well worth the extra 5mins of time
Old 05-07-2015, 09:29 PM   #10
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
And by looking at the shape of the original ull need heat ...what ever u do don't brake them.
Old 05-07-2015, 09:57 PM   #11
IllusionX
I shot liquid wrench on the muffler one. Let it soak for about 5 mins and put the impact to take it out. It came out like butter. It did look like the front ones of OP.
I tried to undo it by hand, never again.
Old 05-07-2015, 10:03 PM   #12
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
One can try that for sure I would be worried about the location its at ...muffler are not a big deal if u snap a bolt ...manifold is another story.
To be safe apply heat to the back over the nut than brake free with hand tool followed with air gun....i would also use an extractor socket.
Old 05-07-2015, 10:18 PM   #13
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Yeah use a torch. A good propane one might get it hot enough to turn it orange and then crack it free. Don't just try and do it cold. More than likely it'll snap. I've done a few and know.
Old 05-09-2015, 04:39 PM   #14
IllusionX
Oh.. I jacked the car up and thought I'd do the gasket. Looking at the bolts, I just said no.
Old 05-09-2015, 06:16 PM   #15
tmontague
tmontague's Avatar
My bolts looked the same as yours when I did them. I sprayed them w/ pb blaster from both sides (you can access threads from other side) and one came off fine. The other bolt stripped but I was able to get it off easily with a bolt off socket.
It's worth a shot and if it doesn't work just take it to an exhaust shop
Old 05-09-2015, 06:40 PM   #16
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
It's not worth a shot ...u got lucky.
If u don't have the means take it to any muffler shop it will cost lot less to fix something that has not been messed with.
You need a torch get it nice and cherry red than use a socket extractor to brake loss afterwards air gun if u like.
Old 05-09-2015, 06:45 PM   #17
IllusionX
Yeah, the other side is rusted completely smooth, I'm not gonna take a chance.
Will bring it to the shop next week or so.
Old 05-16-2015, 02:24 PM   #18
IllusionX
I just came back from the garage to get the gasket replaced.
I was warned at the dealer that aftermarket gaskets won't fit. Well, I got the one from RockAuto, and its slightly too big.
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 10:08 PM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 09:02 AM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 06:01 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 10:23 PM
