Old 05-11-2015, 05:49 PM   #1
waruna01
Drives: 2010 Yaris
Unhappy 2010 Yaris Replace 3rd (center) brake light
How do you remove the center 3rd brake light on a 2010 Yaris Sedan? Do you remove it underneath the trunk? I removed the cable that gets connected to the bulb but cannot seem to take the bulb socket out by pulling or twisting. It looks like L shaped from underneath. Any help is much appreciated.
waruna01 is offline   Reply With Quote
Old 05-11-2015, 10:47 PM   #2
Secretblend
Drives: 2009 Yaris
Here is PDF of how to replace it assuming you don't have spoiler, If you do let me know and I'll add that one.
Just noticed that yours is 2010 and mine is 2009. Don't know if they are close or not.
Secretblend is offline   Reply With Quote
Old 05-12-2015, 02:35 PM   #3
waruna01
Drives: 2010 Yaris
So you replace it by removing the bulb from inside the car behind the rear passenger seat? I thought you remove the bulb from underneath the trunk. I tried lifting the cover from inside the car but it didnt come off. I didnt want to try too hard without knowing if that's the way to do it.
Old 05-12-2015, 02:36 PM   #4
waruna01
Drives: 2010 Yaris
I dont have the spoiler
Old 05-12-2015, 03:49 PM   #5
IllusionX
Drives: 07 Yaris Sedan Aero
There is a way to pull the 3rd brake light to remove it from inside the cabin, which i don't know how since i have the OEM spoiler, so no 3rd brake light inside. :P
Old 05-13-2015, 02:07 AM   #6
Secretblend
Drives: 2009 Yaris
If you look at pdf, you can see that it shows to push it back then up. If you look closely, there are 2 hooks on bottom of cover. Push just enough to clear those two hooks.
Tags
yaris 2010
3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation keiri Third Gen Yaris General Discussion 26 09-04-2020 01:01 AM
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 03:14 PM
Toyota Yaris Battery Light On - Repair gabo General Yaris / Vitz Discussion 1 08-24-2011 08:21 AM
