Old 05-13-2015, 07:29 AM   #1099
kwkshft
kwkshft's Avatar
Drives: 09 Yaris S 3drHB
Send a message via Yahoo to kwkshft
So is the white one going to the crusher?
09 Yaris S
85 Corolla GTS
kwkshft is offline   Reply With Quote
Old 05-13-2015, 07:39 AM   #1100
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by Jason@SportsCar View Post
All of our chassis have reached the age limit for non production/sales units, and will be crushed after the Runoffs.
Yep.
Old 05-19-2015, 08:15 PM   #1101
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Would there be any benefit to using the Yaris SE steering rack (quicker ratio), or are you forced to use the OE Yaris L steering ratio?
Old 05-26-2015, 02:15 PM   #1102
Jason@SportsCar
Interesting find... The bottom bar is the 23mm 2007ish sedan bar I have been using. Middle is the 24mm 2007 hatch bar. Top is the 24mm 2015 hatch bar, the kicker is the 2015 bar is tubular while the others are solid. This will drop unsprung weight, and due to a softer rate should free the car up and help put power down. Going to have to try it out.
For 2015 the Yaris also has aluminum endlinks.
Old 05-26-2015, 02:19 PM   #1103
Jason@SportsCar
Engine/trans from the 2007 are now at home in the 2015. And between the Energy Suspension dog bone, and TRD side mounts, it does not want to budge.
And the interior is now covered in hammered silver.
Old 05-28-2015, 03:30 PM   #1104
Jason@SportsCar
A fellow racer sent me a print he made of the old car, looks amazing, great way to remember it.
Old 05-28-2015, 06:54 PM   #1105
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Wow that's so cool!!
Old 05-28-2015, 06:58 PM   #1106
Bluevitz-rs
Was just looking at the end links for the sway bar. Looks like you could cut and thread one if you needed adjustment.
Old 05-28-2015, 09:02 PM   #1107
CrankyOldMan
The funny thing about torsion is that it's almost entirely carried by the outer diameter of the shaft, so the rate shouldn't be significantly softer. I've tried looking at Toyota parts sites for a 2015, but most don't carry anything newer than 2014.
Old 05-28-2015, 11:59 PM   #1108
Jason@SportsCar
I don't think there is enough material there to pull that off. If you want to dial preload out you only need an adjustable link on one side, so you can always split a pair. In my case the mount on the strut it adjustable.
Old 05-29-2015, 12:01 AM   #1109
Jason@SportsCar
Still trying to get data from Toyota. Typical rule of thumb (for equal OD) is a 20% change in stiffness, 40% change in weight.
Old 05-29-2015, 12:02 AM   #1110
Bluevitz-rs
I have an Echo so Mine are connected to the control arms with the standard rubber sway bar end links.
Old 05-29-2015, 11:31 PM   #1111
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Wow...the front sway bar variants for the models. I am also interested in that 2012 sway bar and links. Great find!
ArmstrongRacing is offline   Reply With Quote
Old 06-02-2015, 02:27 PM   #1112
Jason@SportsCar
Its back on the ground.
Old 06-02-2015, 05:51 PM   #1113
Thirty-Nine
Looks great! Are you using the OE steering rack or perhaps one from a Yaris SE (faster ratio)?
Old 06-02-2015, 05:54 PM   #1114
Jason@SportsCar
Base rack (its actually the one out of the old car, which actually came out of a sedan). With the EPS removed I don't want to further increase steering effort, and for road racing the quicker rack really isn't necessary.
Old 06-02-2015, 09:25 PM   #1115
WorkTL
WorkTL's Avatar
Drives: 2013 Yaris LE
I want to gut mine out now.
WorkTL is offline   Reply With Quote
Old 06-02-2015, 11:29 PM   #1116
Bluevitz-rs
Can you use the fog light holes for anything? Brake cooling or intake?
Sent from my iPod Touch
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 08:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 11:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 06:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 01:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 11:51 AM
