Old 05-21-2015, 02:52 AM   #37
7:34pm
Drives: 07 Yaris
Did you do a 2zr swap at one point?
How was it? And what did you do for mounts?
Originally Posted by ArmstrongRacing View Post
Might as well post up my setup...
Engine- AEM cold air intake, DC header, Magnaflow custom 2" cat--back, NST crank pulley, Simota oil catch can.
Suspension- Tein Basis coilovers(testing purposes only, Normally TRD springs and Tokico HP), Whiteline control arm bushings, TRD strut top mounts, TRD rear sway bar, Eibac crash bolts.
Brakes- Stoptech slotted rotors, MI brake lines, Hawk HP pads
Enkei RPF1 15x7 + Dunlop Z2 205/50R15
7:34pm is offline   Reply With Quote
Old 05-21-2015, 12:19 PM   #38
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Correct, we did perform a 2ZR swap in a fellow NCVC members car. We used a Scion Xd as a donor car, and everything fit perfectly. We then put the 1NZ in the Xd, and that's his daily driver. Scott was a major help with the wiring!
The power increase is noticeable in the lighter Yaris chassis, and even with no mods on the 2ZR it's a blast.
ArmstrongRacing is offline   Reply With Quote
Old 05-21-2015, 12:41 PM   #39
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I'm curious about the cooling system of the Yaris being able to cope with the 2ZR. Any issues to report on that end?
Old 05-21-2015, 01:05 PM   #40
ArmstrongRacing
Data doesn't lie
We used the radiator from the Xd, it's the same size core with a slightly different upper hose outlet. Fits perfectly in the Yaris core support. No cooling issues.
Old 05-21-2015, 09:28 PM   #41
7:34pm
Drives: 07 Yaris
Thanks!
Always was curious about similar platform swaps but unfortunately there doesn't seem to be enough write-ups.
So would you say it was mostly plug and play? Was it a fairly expensive swap? And what mounts were used?
Old 05-22-2015, 12:07 AM   #42
ArmstrongRacing
Data doesn't lie
Mostly plug and play, everything from the XD was moved over to the Yaris. Just a few wiring differences.
Old 05-22-2015, 08:31 AM   #43
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I remember that thread. I had that thread subscribed and was one day put together a write up for that swap. Now that website is gone, so is that information. Any chance one day you guys could get a small write up on the swap. I do remember having to swap some wires inside a fuse box or connectors for something, ABS maybe? You didn't use all the same mounts either right?
-Derrick-
Old 05-22-2015, 12:32 PM   #44
ArmstrongRacing
Data doesn't lie
We are currently doing a write-up for SubCompact Culture, then we can re-build a thread here!
Old 05-22-2015, 01:31 PM   #45
kwkshft
kwkshft's Avatar
Drives: 09 Yaris S 3drHB
Send a message via Yahoo to kwkshft
Do you have the P/Ns for the TRD strut top mounts? Are these for all 4 corners? I may look into getting these, thanks
09 Yaris S
85 Corolla GTS
kwkshft is offline   Reply With Quote
Old 05-25-2015, 11:20 PM   #46
ArmstrongRacing
Data doesn't lie
I don't know what the part number is, I got these from MicroImage(CaliYaris) years ago. You only need 2 for the front strut tops. Cusco offers a mount also....I think.
Old 05-26-2015, 05:26 AM   #47
ilikerice
ilikerice's Avatar
Cusco IICR is a solid mount... wouldn't recommend that for daily driving.
-Derrick-
Old 06-16-2015, 02:18 AM   #48
ArmstrongRacing
Data doesn't lie
Custom aero
Here is a shot of the 2" vertical trunk spoiler I made from Aluminum from HomeDepot. $25 an 1.5 hours labor.
This is completely removable, I only want to use it on Track days and not bump myself into another class.
Old 06-16-2015, 05:25 AM   #49
ilikerice
ilikerice's Avatar
Thats cool. How about getting a long Piano Hinge and rivet it that 2 piece and then tie in a few adjustable anchors to the bottom and you got yourself an adjustable spoiler.....
-Derrick-
Old 06-16-2015, 04:30 PM   #50
ArmstrongRacing
Data doesn't lie
That was my original plan... But due to the dual inward and downward curvature of the trunk, it was a stretch to get the angled base flush.
Old 06-16-2015, 04:52 PM   #51
ilikerice
ilikerice's Avatar
OH yea, I see what you are talking about
-Derrick-
Old 08-07-2017, 01:52 PM   #52
MugenRep
iQ innovator & researcher
MugenRep's Avatar
Drives: 2012 iQ
Hey Sir!
Which Whiteline Control Arm bushings are you using in the Yaris control arms? Are you using the CASTER + or just the normal?
MugenRep is offline   Reply With Quote
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 11:56 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-16-2013 12:44 AM
fnkngrv's custom trailer build log fnkngrv Off-topic / Other Cars / Everything else Discussions 5 10-12-2012 02:24 PM
Build Your Yaris, toyota.com artyin General Yaris / Vitz Discussion 3 05-03-2006 05:52 PM
