Old 05-15-2015, 05:53 AM   #1
itzarthi
Drives: toyota yaris
Post Cigarette lighter
Hello,
I have a Toyota Yaris hatchback from 2007. Yesterday I put an fm transmitter in de cigarette lighter, the fm transmitter got power for a few seconds after that it stops. Since then de cigarette lighter does not give power. I have checked the fuse and the fuse was all right. I also checked If the cables for the cig. Lighter get power but on the cables is no power.
Does anyone know what the problem is?
Thanks in advance.
Regards,
Arthi
itzarthi is offline   Reply With Quote
Old 05-15-2015, 07:23 AM   #2
Besides the CIG fuse, also check the ACC fuse.
Old 05-15-2015, 11:40 AM   #3
itzarthi
I have checked de ACC Fuse this one is not broken any other ideas?
Old 05-15-2015, 01:04 PM   #4
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
Wow!! Unrelated, but I've been wondering where to mount my FM Transmitter for months so it's not in the way, thanks for the logical idea you gave me. Just gonna get a cigarette charger adapter so I can plug it in "when" I need it :D Hope you come right with your problem though.. **
MedMantle is offline   Reply With Quote
Old 05-18-2015, 02:36 PM   #5
itzarthi
Nice to hear that your problem is fixed.
Does some one know a solution for me? Or can I connect a wire direct from the cig lighter to the battery with an fuse between it? So yes how many Ampere does the fuse need?
Old 06-09-2015, 06:12 AM   #6
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Check the FM transmitter itself, if its a cheap shit one then it probably has a bad connection / blown /loose fuse.
JudgeM is offline   Reply With Quote
Tags
cig lighter
How do I remove my cigarette lighter? swayney Cosmetic Modifications (Exterior/Interior) 19 01-07-2016 02:36 PM
Does your Yaris cigarette lighter drain battery? MoneyT8 DIY / Maintenance / Service 6 06-30-2014 01:43 AM
Cigarette Lighter Fuse tommy420 DIY / Maintenance / Service 2 02-13-2014 12:24 AM
Hole beneath cigarette lighter socket? dj92 In Car Entertainment + Electronics (audio / video / alarm) 1 02-06-2014 11:28 PM
Cigarette Lighter Fuse stellar DIY / Maintenance / Service 10 01-30-2010 04:08 PM
