#19 |
![]() Drives: 2007 Yaris Join Date: May 2015
Not sure what your answer has to do with antenna base replacement.
#20 |
Pressing on, I cut the ruku 2 connector off stripped the wire, a solid core wire and a braided around it. Cut the old antenna base off the special wire harness revealing a solid core wire and another twisted core wire. Matched them up and taped them off. Put base back in which by the way is a pita. Locked everything back up.
Getting FM great now but no AM. Any ideas? Last edited by Wincharger; 06-11-2015 at 06:49 PM. |
#21 |
antenna
I need to replace my antenna base and antenna.
hate to bring back to life an old thread but have a question. So you don't have to remove the whole back seat to remove the back right pillar cover and seatbelt? is that correct? so the antenna connection is behind the pillar cover? is that correct? |
#22 | ||
http://www.yarisworld.com/forums/sho...8&postcount=16 Quote:
#23 |
![]() Drives: Toyota Yaris 2007 hatchback Join Date: Jan 2013
Hi guys, sorry to revive this thread. My antenna got smashed by my garage door and I need to replace it. Do you know a place where I cane get one (the base of the antenna). Or give ame an alternative to replace the antenna base with something else. Thanks
#24 |
antenna
Has anybody had to replace their antenna base mount and have to deal with removing the Rear pillar cover which also has an SRS Airbag in it? experiences and what not to do or do before I shop my head off if this airbag go's off.
| Tags |
| antenna, hatchback, headliner |
| Broken Antenna 2008 Hatchback | Hank Corbett | DIY / Maintenance / Service | 9 | 10-15-2015 03:53 PM |
| Replacing Roof Top Radio Aerial (Antenna) | KEVBD | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 01-29-2012 03:17 PM |
| DIY: Installing XM Radio with SureConnect antenna adapter | The Marshall | DIY / Maintenance / Service | 0 | 07-11-2009 10:57 AM |
| Broken Antenna | chip | General Yaris / Vitz Discussion | 6 | 06-13-2009 07:15 PM |
| car antenna question | mikenacarato | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 12-12-2008 02:41 AM |
