Old 05-27-2009, 12:51 PM   #19
jkuchta
Drives: 2007 Yaris hatch (red)
I'm a fan of the ATE Super Blue, not only due to its higher boiling temp., but also for the fact that it's really easy to tell (on the first fluid swap anyway!) when you've got all of the old fluid out.
They also make the same fluid in a more normal amber color, so you can get the color change benefit everytime.
jkuchta is offline   Reply With Quote
Old 06-11-2015, 11:10 PM   #20
attrapereves
Drives: 2010 Yaris 2dr 5spd
Old thread...
I flushed my system and put in DOT4 (as most 2010+ cars use this). However, I noticed after I was done that Toyota calls for DOT3. Will I have any problems?
attrapereves is offline   Reply With Quote
Old 06-12-2015, 06:28 AM   #21
bronsin
bronsin's Avatar
There is one great big can of brake fkuid and all the manufacturers fill their little cans from it. So its all the same.
Same for oil!
But DOT 4 is compatable with DOT 3 it just has a higher boiling point.
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
Brake fluid info... 06vitzRS DIY / Maintenance / Service 5 12-26-2008 12:05 AM
Engine dress up - brake fluid resivoire cap? YarisSedan Cosmetic Modifications (Exterior/Interior) 5 11-15-2008 07:59 AM
