#1477 |
![]() ![]() Drives: Toyota Yaris 1.33 SR Join Date: Nov 2014
Japan racing JR3 16x7" with Bridgestone Ecopia EP25 (195/50 r16). Sorry for the dirty car :D
#1478 | |
![]() Drives: Future 2008 Yaris Hatch Join Date: Jul 2015
#1479 |
Scraper
Drives: '08 Yaris RS 5-Door Join Date: Nov 2014
I've got some BC racing coilovers inbound for my 08 hatch, starting to look at new wheels. Current choices are either 17x9 ET25's or 17x8 ET33's. Thoughts? What would i have to do to fit these?
#1480 |
![]() ![]() ![]() Drives: 09 Blizzard Pearl RS LB Join Date: Sep 2009
It depends what look are you going for. Are you looking at going the stanced route? If so, the 17x9 +25 setup will definitely poke out of the fender. The 17x8 +33 will also poke out but to a lesser degree. If you want the wheels to sit flush with the fenders then you will need a set of camber bolts / shims to dial-in some negative camber. Also, you will need to run stretched tires or do some fender rolling/pulling for clearance when going really low. Also, on most coilover setups for the Yaris, the rear will tend to not go low enough where you may need a set of shorter springs.
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna |
#1481 |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
#1482 |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
All nice rims n wheels, for the most part. Make sure to try and get a good tire, V or Z rated as they are sticky and grippy. The V should be sufficient. I was glad I did this morning 5:15 am, tight road, fallen tree around a bend in my lane, and a car and a full logging truck right at me simultaneous. I tried to stop, ABS kicked in, so swerved left (into oncoming traffic), then right and as I went right, I looked up at logs briefly, while making sure I didn't go off road to the right whilst turning back. So, Guardian Angel check, Michelin V rated Premiers, check. wOw. 12.5 hours later and I am happy to still be here. Some scratches from tree on right side, but, first look only three, and just scratches. Will look tomorrow when I catch my breath. Anyway, to reiterate my point, do not be cheap on tires when buying nice rims please. It does pay off sometimes. That and a guardian angel
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
#1483 | |
Scraper
#1484 |
![]() Drives: yaris belta Join Date: Mar 2009
Please post pics of your Yaris with aftermarket rims here
Xxr 962 18x8.5
tire Toyo 215/35/18 Lower springs Tein ImageUploadedByTapatalk1439144406.149993.jpg ImageUploadedByTapatalk1439144566.678242.jpg Last edited by alfredo; 01-24-2016 at 10:05 AM. |
#1485 |
from Indonesia
Enkei RC-T4 ![]()
#1486 |
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
#1487 |
Scraper
Was gonna wait until I got my coilovers, but what the hell.
Tein S.Tech Springs 205/40 17x7.5 ET43 Unknown wheels, were on the car when I got it. |
#1488 |
Looks great.
Do you ever get any tire rub? |
#1489 |
Scraper
None at all, unless I'm totally deaf.
#1490 |
#1491 |
![]() ![]() ![]() Drives: 2007 Liftback Join Date: Mar 2012
#1492 |
#1493 |
Nice rims, where'd you pick those up from and do you know the specs? I'm looking for rims just like those
#1494 |
![]() Drives: 09 yrs Join Date: Oct 2015
| Post pics of cylinder head (engine) covers here | joelitton | Cosmetic Modifications (Exterior/Interior) | 157 | 08-02-2017 11:36 AM |
| My new 09 yaris! (post bath) | tristan | Photo-Video-Media Gallery | 10 | 10-21-2008 01:23 PM |
