Old 07-13-2015, 10:22 PM   #1
wiirenet
wiirenet's Avatar
Drives: Black '09 2dr HB
Send a message via MSN to wiirenet
Squished Cabin Air Filter
My cabin filter looks like the attached.. I've had it for months, but it's very clean.. I drive every day. The fact that it's warped, is it not working well? I didn't install it, but I can't recall if it was Toyota or somewhere else.
Should I replace it?
I'm thinking about getting this http://www.amazon.com/gp/product/B00...BH9YY7Y480HJ87 and doing it myself.
I know there are cheaper ones, but I have a funky smell from my AC sometimes, so I want something with charcoal. I looked at the Fram Fresh recommended on the forum, but it doesnt actually have a scent/freshener/charcoal right?
thanks!
(oh yea, did i install it back correctly- arrow down? it also pushes out a bit and doesnt seem to fit well..)
wiirenet is offline   Reply With Quote
Old 07-13-2015, 10:26 PM   #2
wiirenet
wiirenet's Avatar
I realized that's an OEM filter by looking at the code here
so why is it so warped??
Old 07-13-2015, 11:45 PM   #3
Secretblend
Drives: 2009 Yaris
According to my manual, it is not inserted correctly.
The stiff sides should be inside on right and left side and the air goes up, not down.
So according to your picture, rotate it quarter turn then turn it right side up. That should fit.
I attached a PDF that shows how it is inserted. Keep in mind it is for 2009 Sedan but I believe it should be same for yours.
Secretblend is offline   Reply With Quote
Old 07-14-2015, 12:01 AM   #4
wiirenet
wiirenet's Avatar
Ohhh thank you! I will flip it. That is how it was when I opened it, sigh. you would think the dealership would know..
Old 07-14-2015, 12:05 AM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
Squished because it was improperly installed.
Old 07-14-2015, 12:28 AM   #6
Yaross
Yaross's Avatar
Drives: 2006 Yaris HB 5DR
air flow direction is correct. it is at the suction of the blower below so air flow is going down. the pdf file shows "UP" side of the filter and not air flow direction.
my guess is that it was inserted in a hurry or it could be a wrong filter (check part number to ensure)
Yaross is offline   Reply With Quote
Old 07-14-2015, 09:25 AM   #7
wiirenet
wiirenet's Avatar
thanks.. i did not install it.. entrusted a shop with it, sigh.
do you think i should trash it and get a new one? i tried to stretch it out, but it just goes back to being squished. obviously there are exposed areas now but i dont know if it's worth replacing because it's so clean...
Old 07-14-2015, 10:41 AM   #8
shepd
Drives: 2007 Yaris 5 door RS
I'd consider replacing it if it won't go back into shape.
If they're $30 like they are where I am, buy a furnace filter and cut it to shape to match the one you have (well, the dimensions it *should* be, anyways). You should get 4 (or more!) filters out of it. Enjoy the savings...
Old 07-14-2015, 10:38 PM   #9
CoryM
Drives: 2009 5-door, 5-speed
That's typical dealer work. They get paid per job, so most mechanics rush through things to make more money. I found lots of filters like that when I worked at a dealership. Filter is garbage as it won't seal properly. It's so clean because all the dirty air has been bypassing it.
Cheers.
Old 07-15-2015, 02:56 AM   #10
kimona
kimona's Avatar
I bought this one from ebay for less than $6:
http://www.ebay.com/itm/Brand-New-Hy...457001&vxp=mtr
Old 07-15-2015, 11:09 AM   #11
esse10
Drives: 2009 yaris 2 door
flow
From looking at the picture the airflow is correct the filter just needs to be rotated around 1/4 turn.
esse10 is offline   Reply With Quote
Old 07-17-2015, 08:54 PM   #12
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
Hi kimona
I just ordered 3 of the cabin air filters through the link you provided. Price is great. However, after ordering I wanted to confirm compatibility and it doesn't list my 2008 Yaris LE 4-Door Hatchback as one of the compatible models. However it does list others such as the 2008 Yaris S Hatchback 2-Door.
Do you believe it would be the same?
white_rice is offline   Reply With Quote
Old 07-17-2015, 09:18 PM   #13
^ same.
Old 07-17-2015, 09:29 PM   #14
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I just bought a home HVAC filter and cut it into 6 pieces that would fit my car.
Why didn't the Yaris come with air cabin filter? detroiter DIY / Maintenance / Service 19 11-21-2012 05:42 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
Cabin air filter waste of money? jambo101 DIY / Maintenance / Service 27 08-11-2010 02:04 AM
cabin air filter kaboom DIY / Maintenance / Service 108 03-31-2009 09:00 PM
CA: Free Cabin Air Filter, Socal only. kunfuzion Items for Sale by private party 6 03-24-2007 11:34 PM
