Old 07-31-2015, 12:03 PM   #1
Ranger SVO
Drives: 2010 Yaris
What Maintenance Might Be Needed??
I bought my 2010 Yaris in January 2010. I currently have around 41,000 miles on it.
I have done oil changes once a year because I only average around 7000-7500 miles per year. I use Mobil 1 5W30 Extended Performance. One bottle of Chevron Techron fuel injection cleaner is used at each oil change.
I just got back from a vacation, the Yaris went from Abilene Texas to Phoenix Arizona, to the Grand Canyon, to Las Vegas back to Abilene. The car performed flawlessly. Average gas mileage for the overall trip was 42 mpg. This is the third trip like this for the Yaris (last year I took the 2012 Honda Civic).
The air filter, the cabin air filter and the oil was replaced just before the trip.
The trans fluid looks nice and bright red.
What about the coolant?
Is there anything I really need to look at?
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
Truth does not change because it is, or is not, believed by a majority of the people.
Giordano Bruno
Ranger SVO is offline   Reply With Quote
Old 07-31-2015, 12:43 PM   #2
bronsin
bronsin's Avatar
Coolant is good for five years but many just leave it in there. I find its easy to change however by just draining it with the radiator drain. It all comes out in my experience.
Front brake pads should be checked too at this time. If theyre half worn out you can guess they'll need to be done around 80k.
Have the recalls been done? Especially the front suspension bolts which can rust the heads off. Doubt that's an issue in TX.
Probably a good idea to get the car up on ramps first the front then the rear for an inspection for damage.
I find fault with using techron. Unnecessary in my experience and just might cause a problem.
bronsin is online now   Reply With Quote
Old 07-31-2015, 01:18 PM   #3
Ranger SVO
Drives: 2010 Yaris
I will definitely look at that, is Zerex Asian OK for the Yaris?
I checked the brakes recently because they squeak a little when they get hot. They squeaked alot in Vegas, alot less here in Abilene (not as Hot). They looked to be in excellent condition.
The recall for the seat track problem and the recall on the spiral cable have been taken care of.
So I will get it up on ramps and check everything out and give the car a good overall inspection. I'll get the coolant done soon. Thanks for your reply.
Augustus de Morgan
Giordano Bruno
Old 07-31-2015, 02:59 PM   #4
bronsin
bronsin's Avatar
[QUOTE=Ranger SVO;766298]I will definitely look at that, is Zerex Asian OK for the Yaris?
QUOTE]
I would bite the bullet and go for genuine Toyota coolant. You could really leave it in there forever (well, a LONG time).
Probably its alright to use what you suggest..
I think the Toyota brake pads, air filters, and belts are the best and that what I get. Unless they want ridiculous money.
Oil filter...no...the cheapest will do if changed per the OM.
Old 07-31-2015, 05:30 PM   #5
Ranger SVO
Drives: 2010 Yaris
Again I thank you to take the time to respond.
I have an appointment at Discount Tire to have the tires rotated and balanced on Monday, the Toyota dealer is right across the street. I'll look into the price. Hopefully its not too outrageous.
Again Thanks
Augustus de Morgan
Giordano Bruno
Old 08-01-2015, 09:59 AM   #6
bairjo
Wouldn't hurt to clean the Mass Air Flow sensor at this time....
Old 08-01-2015, 10:56 AM   #7
ex-x-fire
I probably wait to do the coolant until the water pump starts seeping.
Old 08-01-2015, 11:27 AM   #8
Ranger SVO
Drives: 2010 Yaris
Way good idea. I even have some CRC Mas AirFlow Cleaner. My 1993 Ranger has a K&N Air Filter and I tend to slightly over oil it. Anyway, CRC Mas AirFlow Cleaner always fixed idle problems that occured shortly after cleaning.
Adding that to my list of thing to do next week end.
I'm going to bring up my 1993 Ranger again. I changed the coolant every 50,000 miles and I always added one bottle of Prestone Radiator Complete Care and Never Had A Cooling System problem. At 221,000 miles, not one cooling system problem
Just for the heck of it I added half a bottle to the Yaris (only a 5qt cooling system) shortly after I bought it. I wonder if it will also help the Yaris.
I think I'll go ahead and change it next weekend (along with a light cleaning of the Mass AirFlow sensor), thank you for your input.
Augustus de Morgan
Giordano Bruno
Old 08-01-2015, 01:25 PM   #9
bairjo
I wouldn't mix anything with the Toyota coolant. If I recall, it is a pretty unique formula that they seem pretty adamant about not mixing any other fluids with it....I could be wrong so read that section in the owners manual or the label on the jug from Toyota.
Advice needed on maintenance and cosmetic repairs md3k DIY / Maintenance / Service 12 08-07-2012 02:30 PM
4-wheel alignment for 5000 mi. maintenance????? Yari-Chan General Yaris / Vitz Discussion 44 01-28-2011 10:00 PM
What to look for with maintenance needed light on? 09box DIY / Maintenance / Service 3 09-24-2009 02:11 AM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 04:14 PM
