Old 06-02-2015, 02:27 PM   #181
haunter1982
Drives: Yaris 1.33; Edition 2014;
Just found out that 45186-52030 C0 is not the right part for my steering wheel. 5$ spent for nothing. dammit.
But now i have the flexible rubber part and can make the origin part fit right.
haunter1982 is offline   Reply With Quote
Old 06-02-2015, 08:22 PM   #182
Yes. The part for the European Yaris is a different shape. I have the correct part number listed somewhere in this thread.
Old 07-16-2015, 11:05 AM   #183
apmatzen
apmatzen's Avatar
Drives: Toyota Yaris 2015 1.0VVT-i T2
Three weeks away I bought a 2014 Yaris (2015 model).
It has the 1.33L 1NR-FE engine.
Does that one have the wiring?
Toyota Yaris 1.0VVT-i T2
apmatzen is offline   Reply With Quote
Old 07-16-2015, 08:34 PM   #184
Yes it does. All you need is the stalk with harness and the steering wheel side trim piece.
Old 07-17-2015, 03:54 AM   #185
apmatzen
apmatzen's Avatar
Is it something you have in stock?
Old 07-17-2015, 09:22 PM   #186
I stock the stalk and harness and the trim pieces for the US 3rd generation, but the European 3rd generation Yaris have a slightly different steering wheel back cover, so you'd have to grab that piece from the dealer.
Old 07-27-2015, 12:44 PM   #187
meszar
Drives: Toyota Yaris 2014
Hi CTScott, I would like to ask whether it is possible to install cruise control Yaris 1.0 2014 purchased in the Czech Republic?
meszar is offline   Reply With Quote
Old 07-27-2015, 10:05 PM   #188
I don't believe that the ECM for the 1.0L supports cruise control.
Old 07-28-2015, 03:52 AM   #189
apmatzen
apmatzen's Avatar
Hmm...I've had 1.0 2012 and I asked the local dealer If they Can install cc in the car...and they can.
But I never got it installed, because I bought another car.
So it can be done, but its very expensive.
Old 07-28-2015, 11:37 AM   #190
meszar
It did not please me very much. but it is interesting that Toyota offers 1.0 liters senso packet, which includes cruise control. I do not feel that because of this changing in the production of the control unit.
Old 07-28-2015, 07:26 PM   #191
I think something might have gotten lost in translation. What do you mean by "senso packet"?
Old 07-29-2015, 09:43 AM   #192
meszar
when I bought Yaris, and the opportunity to take it with Senso Packet, but I could not wait a month, unfortunately.
Senso packet includes:
Dual-zone automatic air conditioning
Rearview mirror with automatic iris
Smart Entry & Start
Twilight sensor
Rain sensor
The air-conditioned glove glove box
Cruise control
Old 07-29-2015, 01:30 PM   #193
Interesting. So, in that case it sounds like the 1.0 can now do cruise. If you want to be sure, you just need to pull the lower steering column cover and check for 12v on the CCS wire (pin 1 of the spiral cable connector).
Old 07-30-2015, 08:38 AM   #194
meszar
Which pin do you mean? :)
Old 07-30-2015, 01:07 PM   #195
On the black connector on the upper left in the first picture, measure the voltage on the grey and brown pins with the ignition in the ON position (engine not running)
Old 08-03-2015, 04:25 PM   #196
meszar
Brown - 0
Grey (right of brown) - 5 - 5,5
Old 08-04-2015, 11:47 AM   #197
panosvo
Drives: Yaris 2013 Diesel Active
In my Toyota Yaris D4D 2013/05 model STYLE TYPE- NLP130L-CHFSXW, everything is in place, even the clutch switch s in place, but unfortunately the pin1,2 voltage is not there. So the ECM does not have the cruise control function in it. Is there a way to add it? Just wonder
Here are the photos!
panosvo is offline   Reply With Quote
Old 08-04-2015, 07:09 PM   #198
Brown - 0
Interesting. I have not had the opportunity to measure the voltage on the CCS wire of a third generation Yaris, so the 5V, rather than 12V might be OK.
Try jumping the brown to the grey with the Ignition ON, but engine off (you can use a bent paper clip or small piece of wire). If you touch those two terminal together briefly you should be able to toggle the cruise control symbol on and off on the cluster, if it works.
cruise control. 2012
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
