Old 09-02-2015, 05:52 PM   #1
Paul3086
Drives: 2010 Yaris Hatchback
2016 Model Auto Transmission?
Does anyone know if the 2016 Yaris will be a 4 or 6 speed auto transmission? Was really looking forward to it having a 6.
Paul3086 is offline   Reply With Quote
Old 09-02-2015, 05:57 PM   #2
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
4 speed
mr9865 is offline   Reply With Quote
Old 09-02-2015, 06:24 PM   #3
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
You won't see a new drive-train/engine in a "Yaris" until 2017 when Mazda builds it for Toyota (likely a rebadged 2016/2017 Mazda2 Hatchback) - meaning you will be getting current-gen Mazda quality not Toyota quality at that point for the "Yaris".
The 2016 Scion iA (a rebadged 2016 Mazda2 Sedan) uses a SkyActive direct-inject engine, and 6-Speed manual/automatic, and everything else Mazda, minus the cosmetic changes to the front grill/bumper.
Considering that the new 2016 Yaris Sedan in Canada is the same rebadged Mazda2 as the 2016 Scion iA, expect the 2017 "Yaris" hatchback in both the USA/Canada to be pretty much the same thing mechanically as that.
Kalispel is offline   Reply With Quote
Old 09-03-2015, 07:09 PM   #4
nookandcrannycar
Originally Posted by mr9865 View Post
4 speed
^^^^^ This. Someone, within the last few days, posted a PDF fact sheet that Toyota put out for the 2016 Yaris, and the 4 speed auto is listed.
Old 09-03-2015, 07:13 PM   #5
nookandcrannycar
Yep. Sad.
Old 09-04-2015, 11:34 AM   #6
miami
Drives: 2007 Yaris LB Base
Originally Posted by nookandcrannycar View Post
Yep. Sad.
Not so sure about that. Mazda has been making very nice cars as of late, and I don't think Toyota would put it's reliability-based reputation on the line if it had serious concerns regarding Mazda quality.
The DI engine issue is becoming pervasive, since manufacturers are forced to adopt the technology in order to meet CAFE standards.
However, Toyota did do a good job with its hybrid fuel injection system implemented in the GT-86. A Mazda skyactive engine with Toyota's hybrid fuel injection system would be the perfect combination!
miami is offline   Reply With Quote
Old 09-04-2015, 01:44 PM   #7
nookandcrannycar
I hope you end up being right .
Old 09-04-2015, 05:29 PM   #8
miami
me too!
Old 09-04-2015, 10:50 PM   #9
Kalispel
Kalispel's Avatar
Personally, I'm wary of the new "direct inject" engines, as they "run hotter", require very stringent build quality/durability to prevent premature failure, and really aren't very compatible with fuels using ethanol additives (almost all U.S. sold fuel) - meaning they require more preventive maintenance to keep from gumming up, etc. I might be more receptive towards them if 0% ethanol fuel was readily available. As it is, the current negatives just aren't worth the slight boost in MPG and horsepower that they deliver - at least to me.
I prefer the reasonable performance and time-tested durability/quality of the current Yaris VVT-i engine, but would avidly prefer that Toyota put a "Corolla horsepower version" (~130hp) of the VVT-i into the Yaris SE instead.
Old 09-05-2015, 02:38 AM   #10
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
DI engines will go much longer without issues if people would actually DRIVE them in most in stances . It is no different that multiport or ither variants. You need to put them up into their higher rpm ranges every so often to burn the garbage out. The problem is that most folks don't do that.
Sent from my SCH-I545 using Tapatalk
Old 09-05-2015, 07:20 PM   #11
nookandcrannycar
DI engines will go much longer without issues if people would actually DRIVE them in most in stances . It is no different that multiport or ither variants. You need to put them up into their highe rom ranges every so often to burn the garbage out. The problem is that most folks don't do that.
Sounds as though I need to gain a temporary lead foot .
Old 09-05-2015, 07:27 PM   #12
fnkngrv
fnkngrv's Avatar
The boggest issue really is that if you are always just nursing the gas you will get in trouble quicker since DI doesn't have the ability to wash fuel over the valves.
Old 09-09-2015, 10:00 PM   #13
sg11
Drives: 2010 Liftback
Noticed this a while ago. Not sure if its anything new. Thought I'd share.
http://www.fueleconomy.gov/m/m.do?ac...ta&model=Yaris
Seems to indicate a possible 6 speed automatic and manual for 2016. Possibly borrowed from Mazda? Only time will tell....
Sent from my VS980 4G using Tapatalk
sg11 is offline   Reply With Quote
Old 09-09-2015, 10:08 PM   #14
By the "New Car Features" spec it is still the U340E 4 speed auto that has been used in all previous USDM Yaris.
Old 09-09-2015, 10:43 PM   #15
kimona
kimona's Avatar
Drives: 2014 White VITZ
which, BTW, is a brilliant piece of work... better than the 6 speed automatic in my Camry.
Old 09-10-2015, 09:23 AM   #16
sg11
What's wrong with the Camry auto?
Old 09-10-2015, 12:17 PM   #17
kimona
kimona's Avatar
Nothing wrong with the 6-speed Camry transmission, but it's not as intelligent as the 4-speed Yaris automatic. Unlike the Yaris, it's not always as smooth shifting and occasionally hunts for the gear. The Yaris upshifts and downshifts flawlessly. I can't say the same for the Camry.
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 10:07 PM
2009 Sedan Auto Transmission Oil Change DIY 09sedan DIY / Maintenance / Service 37 01-07-2018 03:09 PM
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 02:45 PM
instrument cluster-TACH "S" model Lewis DIY / Maintenance / Service 65 11-15-2009 03:19 AM
