Old 09-29-2015, 06:39 AM   #1
alweasel
Drives: 2007 Yaris
Radio Options on a 2007 Yaris Sedan
Hello All.
I just bought a 2007 Yaris last night. And it comes with the standard gray / silver stock radio. I want to change this as quickly as i can to something that will do satellite radio and bluetooth and iPod/iphone integration.
Because of the size of my radio now, am i limited in what radio i can get?
Thanks for your help.
Alweasel
P.S.
I really used this site before i bought the car to see what i was getting.
And i won't be doing any DYI audio work since i am terrible with cars.
alweasel is offline   Reply With Quote
Old 09-29-2015, 08:29 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
It doesn't matter. You will need an adapter kit whether you are getting a single or double din.
Sent from my A0001 using Tapatalk
Old 09-29-2015, 08:11 PM   #3
With the silver, one piece setup that your sedan has, you need to purchase the radio trim piece from Toyota, which will replace that unit with a trim piece that has the standard Toyota opening. Then, you can purchase a standard Toyota or Scion radio, which will fit and will be plug compatible with the wiring harness to your current radio. If you purchase a 2012 or newer radio you will need to also purchase an antenna adapter, as the newer Toyota radios use a different connector.
Old 10-01-2015, 12:20 PM   #4
alweasel
Drives: 2007 Yaris
Thanks both of you for your information.
I will call my local dealer for the trim piece and antenna adaper.
I'm glad there is a site like this for newbies like me?
Thanks again all.
Alweasel
Rims + tires for a 2007 Yaris sedan Shmomi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-18-2011 05:03 PM
2007 and up Yaris Sedan S McDizzle New YARIS Purchase Forum 3 12-03-2009 02:42 PM
