Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 02-21-2010, 07:48 AM   #37
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Hi
I was wondering if you could swap the ECU with one from a Toyota Avensis/Auris/Verso 1,8 Dual VVT-I? They have got 147hp. instead of the 133hp. in our Toyota Yaris 1,8 TS.
Look at the specifications here: http://www.toyota.dk/cars/new_cars/a...fullspecs.aspx
I think itīs the same engine, so I would think itīs just the ECU thatīs decide the amount of hp.
Does anybody know if it could be done?
Regards Steven.
Danish Yaris is offline   Reply With Quote
Old 02-21-2010, 11:20 AM   #38
kr1
Show & Go
kr1's Avatar
Drives: Yaris HSD -12, GT86 -12
Hi.
Itīs not the same engine. So, swapping ecu makes no different for yaris.
kr1 is offline   Reply With Quote
Old 02-21-2010, 11:59 AM   #39
Danish Yaris
Hi
Are you sure itīs not the same engine, as they are both 1,8 Dual VVT-I? Itīs not a VVTL-I like the Toyota Corolla TS.
Regards Steven.
Old 02-23-2010, 02:02 AM   #40
shtou
Drives: YARIS TS 1.8
Originally Posted by Danish Yaris View Post
Hi
Regards Steven.
it's not.check this:
http://en.wikipedia.org/wiki/Toyota_ZR_engine#2ZR-FE
the new 1.8L (147HP) engine has 2ZR-FAE and TS engine has 2ZR-FE code.one letter is missed from our engine .the diference betwwen torque is not much-5NM.and the new engine has Valvematic system.
shtou is offline   Reply With Quote
Old 03-02-2010, 10:22 AM   #41
lammy29
Drives: Yaris
Originally Posted by CASTREX View Post
2) NST Short shift kit (SSK) Will only work on the 07/08 5 speed TS. It will NOT work on the 6speed shifter.
3) NST Cable Metal Bushings. Will work on on the 5speed TS. Not yet confirmed on the 6speed but it looks like it would work.
Just wondering if the in cabin shifter fits and both of the brushings aswell.
lammy29 is offline   Reply With Quote
Old 03-22-2010, 01:04 AM   #42
Yoshua
Hi All,
I have a question regarding to the speedometer cluster of my yaris sedan 07. I'm interesting in swapp the cluster for a 2010 the only different is that mine just have one clock and the 10 has 2 one for the miles and the other for RPM but I'm not sure if I do a swapp the RPM gonna works or just is plug and play? excuse me for the inglish I'm from PR so someone could help on this, please. Thanks
Yoshua is offline   Reply With Quote
Old 04-22-2010, 04:15 AM   #43
barebonedvitz
return of the comeback
barebonedvitz's Avatar
Drives: white '08LB..very nice,i like
You do realize the TS engine is the same as the scion xd and the scion xd and yaris share the same chasis platform.
In other words you just need an engine and a ECU out of a XD to do the swap.
No one has done it because the gains do not justify the investment. If you have a yaris with a broken engine on ther other side... this swap would make a lot of sence
ya pretty i've been aware ever since the new engine came out... i was just wondering if this 1.8 would have different mounts... but since no one has done it... i guess i'll just have to do my own homework on this.. thanx castrex :)
Everything will be ok in the end... if it's not ok, it's not the end.
93 Civic Si- SC/B18B1 - street beast
07 Red/BlackTop Yaris LB - died in a sandwich in 2010@168K.
08 White Yaris LB - daily beatnut...round 2!
barebonedvitz is offline   Reply With Quote
Old 04-22-2010, 12:34 PM   #44
captaincrunch
Chris
captaincrunch's Avatar
I hav a stock intake with just a regular k&n filter. Do you think upgrading to a CAI would make of a difference? I need something to do on my car so if a did that I might get a throttle body spacer too.
captaincrunch is offline   Reply With Quote
Old 08-20-2010, 02:31 PM   #45
carlghoul
Drives: Fit, Scion XA, '91 Ford Festi
I want to use my Yaris hatchback on rough backroads, so I could use more ground clearance. The Scion xd has 6 1/2" ground clearance vs the Yaris' 5 1/2". Anyone know the length of the xd's springs?
carlghoul is offline   Reply With Quote
Old 09-13-2010, 09:54 PM   #46
lammy29
Drives: Yaris
http://www.remusuk.com/model.asp?id=...0II&man=Toyota
tempted to buy it but dunno what it sounds like....
http://cgi.ebay.com/ebaymotors/Toyot...Q5fAccessories
is the rear sway bar easy to fit?
Old 09-21-2010, 11:09 AM   #47
candy_red
Drives: 2000 Yaris 1.0 & 2007 Yaris Ts
How much of a difference you get with the NST pulley?
It just improves the will of the car to rev in simple words right?
No actual hp gain or.....
candy_red is offline   Reply With Quote
Old 02-04-2011, 01:55 AM   #48
shtou
on the site it says that ~8HP more.members who installed it say it feels some gain.i'm thinking to buy one for me.
Old 02-12-2011, 08:53 AM   #49
PumpkinSteve
PumpkinSteve's Avatar
Drives: Yaris SR 1.8
I'm interested in the NST pulley but there's a video on youtube of a failed pulley, bearings came loose in the centre or something...now I'm worried.
PumpkinSteve is offline   Reply With Quote
Old 08-14-2011, 05:02 AM   #50
lammy29
Drives: Yaris
http://www.hks-power.co.jp/db/produc...2003-AT016.pdf
anyone know if it will fit?
Old 02-09-2012, 01:14 PM   #51
rayy
Drives: sr
-scion xd 1.8 2zrfe weapon r header
fits %100
rayy is offline   Reply With Quote
Old 02-10-2012, 08:32 AM   #52
fits %100
Great news.
Old 11-08-2015, 11:50 PM   #53
pixelpusher
Drives: 2005 Echo
I have '05 Echo brake parts that I was going to put on my Echo hatchback before it was totaled in an accident.
Now I'm looking to purchase a 2011 Yaris. Does anyone know if my '05 Echo brakes (Rotors, pads and brake lines) will fill on an '11 Yaris.
Thanks
pixelpusher is offline   Reply With Quote
Old 06-21-2017, 02:59 AM   #54
Hard_Yaris
Drives: 07 Yaris
Thanks
Can anyone help me or pixelpusher with what other cars parts fit a 2005 echo hatchback?
I read Scion xA and xB models do, at what age range do they work for the echo?
I'm really looking for suspension parts,
Hard_Yaris is offline   Reply With Quote
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 10:08 AM
The official Yaris Taillights thread Razr Cosmetic Modifications (Exterior/Interior) 40 06-12-2007 10:08 AM
