![]() Drives: Toyota Yaris 1999 Join Date: Nov 2015
Hi
My Toyota Yaris 1999's fuel tank is leaking due to a rusty exterior. I have looked at the possibilities of sanding it down, but because it is very rusty, and I do not dare to use any power tools on it (because of possible explosion danger), I have decided that I want to purchase a new one. However, the new tanks I have found surfing around the web are all said to be "empty" inside. My old tank does however contain some parts inside of it, for example some sort of a plastic container right underneath the fuel pump. These parts are sitting fastened inside the tank, and are too large to be removed through the top hole. I am therefore wondering if I have to worry about new tanks having such parts inside? And, does anyone know exactly what these parts are for? Thanks in advance. I can include pics if necessary. Sincerely, norwegian who wants to keep driving his kickass 99 yaris
Last edited by Orange; 11-19-2015 at 09:11 PM. Reason: To inform people that the issue was solved |
Actually that is the fuel level sender and pump assembly. It does fit back out through the top hole:
They might be referring to the baffling inside the tank.
#4 | |
Hi again, thanks for replies, and sorry for being so late to respond myself.
I think this might be it! It's fun tho that the word baffling could also mean to confuse.. I will include some pictures this time to clarify. Again, the question is, do I need to worry about these parts coming with a new tank? |
Those are the baffles. They are part of the tank (as you noticed they are not removable through the pump hole), so they should definitely come with a tank. By empty they likely mean that it does not include the pump and sender unit.
#6 | |
| Tags |
| 1999, fuel, replacement, tank, yaris |
| Just filled up the tank with 91 octane premium fuel | darkmoon87 | General Yaris / Vitz Discussion | 105 | 10-02-2016 08:35 PM |
| 2006 Yaris Fuel Pump and relay | aleksii | DIY / Maintenance / Service | 8 | 04-22-2014 06:00 AM |
| 07 cranks, won't start--no fuel?... | tylerwatts53 | DIY / Maintenance / Service | 18 | 03-03-2014 05:03 PM |
| Fuel Tank problem | devinlamothe | DIY / Maintenance / Service | 14 | 02-04-2009 06:10 PM |
| Low fuel light | falkor_99 | General Yaris / Vitz Discussion | 35 | 08-24-2007 03:20 PM |
