Old 12-20-2015, 01:02 PM   #1
fazil
Drives: Yaris 1.3 Terra Mk2 2006
No crank with full battery
Hello,
I'm new to this forum. I have a 2006 year Yaris 1.3 Mk2 gasoline car that has done 70k km so far, and served well for 10 years as i was the first owner.
But this morning she gave up at last.
When i turn the key, there is no crank. Clutch safety switch works fine.
Battery is like new condition, and seems full. Dashboard seems fully working and other electrical parts work fine also. I can just hear a relay clicking after i turn the ignition. Nothing else happens.
So any help would be useful for me. May be just a relay or fuse problem, may be the starter motor is dead, i have no idea.
fazil is offline   Reply With Quote
Old 12-20-2015, 01:11 PM   #2
nortonfb
Drives: 2007
Do you have a volt meter? You can check battery voltage.
Do you have headlights? (This is a crude test) yes, charging is OK. With headlights on have someone watch the lights and turn the key to start. If lights dim short in starter.
Lights stay the same it's an electrical issue, time to check fuses, connections.
nortonfb is offline   Reply With Quote
Old 12-20-2015, 01:23 PM   #3
fazil
I didn't check with a Voltmeter, but lights don't change when i turn ignition.
Dashboard lights completely goes out when i turn ignition.
Just after turning the ignition, I hear a relay clicking and deep weeping voice following like fuel pump priming and then relay clicks again and nothing happens.
No crank and no intension to start.
Which fuse or connection shall i check?
Car was working fine yesterday, no issues, just the fuel level was very low, blinking fast but i put 4 lt of gasoline this afternoon. So fuel shouldn't be an issue.
Old 12-20-2015, 05:28 PM   #4
alanwagen
Jump start
I think it is the battery. Try jump starting it. Won't cost you a dime either.
Old 12-20-2015, 07:59 PM   #5
tmontague
tmontague's Avatar
My vote is the battery
Old 12-20-2015, 08:50 PM   #6
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
3 votes for battery.
NYC-SE is online now   Reply With Quote
Old 12-20-2015, 10:44 PM   #7
sex
sex's Avatar
Drives: 09 5DR
You have a manual right? Can it be push started?
sex is offline   Reply With Quote
Old 12-21-2015, 03:20 PM   #8
fazil
Thanks for the replies. But it's not the battery. I charged the battery this morning, and i tested starter relay (That little blue relay in the fusebox) and all works good. Then i tired to just knock the starter motor with hammer, while my friend was cranking the engine and it started at the 3th try. I've read this knocking starting style in a forum or somewhere in internet. So it works
I guess the car needs to go to service soon for a starter disassembly. May be the brushes are bad. I'll write back soon.
Old 12-21-2015, 03:32 PM   #9
NYC-SE
NYC-SE's Avatar
I stand corrected. Definitely the starter in that case.
Old 12-21-2015, 03:37 PM   #10
fazil
Looks like that, but starter solenoid is also possible as i read in other forums.
We'll see.
Here is a video about diagnose:
https://www.youtube.com/watch?v=pSrHs87TEKQ
How Long Should an Original Battery Last? molinee DIY / Maintenance / Service 127 11-29-2015 10:26 AM
New Battery YarisFrog DIY / Maintenance / Service 6 01-28-2013 11:44 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
October 16th Sunday 2-6pm, Shannonville Full Track event! 20th event of 2011!!! Touge.ca Canada 2 10-06-2011 12:07 AM
