DIY keyless entry Viper 211HV w/ pics
I wanted to put all of the info in one place so that someone could purchase a keyless entry system and install it within a couple hours using this guide and only this guide.
The following information will be specific to the Viper 211HV keyless entry, but it will be virtually the same for the majority of other keyless entry systems and even remote start or alarm systems. The vast majority of the images in this DIY are from YW member CTScott as well as the majority of information. I would not have been able to make this DIY is it wasn't for his vast electrical knowledge and great images of the connectors. Most of this information is floating between 2 or 3 threads that are more specific to remote starters and there was an error on one of the threads that hadn't been updated. YW member DanQ apparently had a full DIY done for the 211HV system but it is no longer an active link. I will be updating this DIY with some pics of my install next week, but for now I have all of the wire images that you need to do this install. Things you'll need: 18-22 gauge t taps rescue tape and/or electrical tape needle nose pliers 1/4" ring/loop connectors for 18-22 gauge wire crimper wire stripper female 1/4" connector for 18-22 gauge wire 9/32" drill bit drill 4 self tapping screws (can't remember the diameter that fits, but preferably the smallest you can get at a hardware store 10mm socket (for battery terminal) Here is an image of the wires you need to use and what each one is used for: ![]() First choose where you want to mount the module. I decided to use self tapping screws and mount it on the panel below the steering wheel just above the clutch. It is just to the right of the OBD connector and does not get in my way. Drilling the crews was extremely easy and it makes it easily accessible if I ever need to disconnect it for any reason. I ran the LED wire under the dash over to the A pillar, up the A pillar and I installed it in the roof flashing down onto the windshield in front of the drivers seat. The wire isn't long enough to reach to the middle of the windshield like most alarm systems so I settled with above the drivers seat. I originally wasn't going to mount te valet switch since I won't be using it much after the initial install since this is only a keyless entry system, but I decided to just install it as having to connect and disconnect it if I ever needed to use it was a pita. I mounted it just to the left of the steering wheel and to the right of the cup holder and ran the wire under the dash. The manual states to use a 9/32 drill bit and it fits the led and valet switch very snug. I started by taking the wiring harness (not connected to the module) and crimped loop connectors onto all the wires for ground. I used 1/4" size so that they'd fit the ground bolt at the drivers side kick panel. There are 3 ground wires in total because the violet and violet/black wire are connected together after the fuse. I then took at 1/4" male connector and crimped it to the 12v constant power wire (H1/1 red wire). I use heat shrink tubing on the the positive wires and nothing on the negative (ground) wires. I then got to work taping into the proper wire for each wire coming from the module. I used T-taps and ended up using 2 sizes. You could get by with 18-22 gauge t taps, I had originally started using 14-18 gauge t taps but I found they weren't ideal as some of the wires are very small that you need to tap into. Make sure you really clamp down with pliers on the t taps to make sure you have properly exposed the wire so the connection is good. ***make sure the negative terminal is disconnected when doing any electrical work on your Yaris*** Once I had all of the proper wires spliced and they were all double checked, I connected the negative terminal back on the battery, connected the wiring loom to the module and tested out the key fob's. Now if your module is working properly and your taps are all good then you should have the following functions working: *Note: Your parking lights will not be working unless you have moved the 15A fuse located in the module over to the second position. This is its original position: ![]() This is how you want to set it up for the parking lights to be triggered by the negative flash: ![]() It is a very subtle difference but the fuse is just moved over one more prong. This fuse can be accessed by the little plastic window that you slide to remove. You will see a 15A mini fuse under that window. Just use needle nose pliers and pull it out. You will see 3 female prongs, insert the fuse into the middle prong and the other one that was previously not being used from the stock set up. You parking lights will now work assuming you have tapped the wire properly. -car locks/unlocks -drivers door only unlocks when unlock is pressed once. If pressed again 2 x then all doors unlock -horn beeps when unlock is pressed twice -parking lights flash when lock/unlock -dome light stays on for 1 minute when unlock is pressed. Blue LED should flash continuously when the car is locked. -when ignition is turned on doors should lock within 3 seconds and when ignition is turned off drivers door should unlock. You do not have to wire all of these wires if you don't want all of thee features. Some choose to leave the ignition wire unwired so the car doesn't lock or unlock with the ignition (you can turn this feature off if you like). Guide to what wires to splice and where they're located. 12v constant power: Located in the drivers side under dash fuse panel (under the drivers cup holder behind the removable pocket). You will see an empty spot with two male prongs sticking out. Attach the red wire from the harness which has the female end crimped onto it to the top male prong. ![]() Grounds: All 3 grounds go to the screw under the drivers side kickpanel which is already a ground point for a wire. Just add the 3 loop ends to the bolt and then screw it back on. ![]() Dome light pink wire: Located in the drivers side under dash fuse panel. You will see the 4k connected which has a pink wire coming out. Disconnect the connector to give you more room and movement to use the t tap. ![]() Lock and Unlock wires: Located under the drivers side kick panel you will see two connectors. You want the bottom one. The brown wire is for lock and the green is unlock ![]() Horn wire: Under the steering wheel is a white connector that only has one black wire coming from it. This is the horn wire that you need to tap into. ![]() Ignition wire: From the ignition connector there is a thicker green wire coming out of it. This is the ignition wire that you want to tap into. ![]() Parking light wire: On the turn signal stalk connector there is a white wire, this is the parking light ground (-) wire. On most Yaris' this should work fine. However if you look at that connector and the wire in pin 10 (4th from the right in the same row) is green and not white/black then you have to use the positive (+) parking light wire. This is shown in the picture below. It is harder to access and not nearly as convenient as the white (-) wire. For the negative parking light wire (ground): ![]() For the positive parking light wire: ![]() I wrapped all of the t taps that I could access with self sealing silicone tape (rescue tape) as I find it works way better than electrical tape and makes the connection waterproof. I have done this for all my connections in my engine bay when I wired my HID projectors and I have yet to have any water issues. I know this is overkill as this is located inside the car, but it's easy to do and it helps with some piece of mind. My module ended up having as issue from the factory and was not grounding the parking lights so they were not flashing. I used a paper clip and disconnected the white module connector and jumped the parking light pin to a ground pin and the lights went on. This ensures that the wiring and taps were all good but the module itself is not grounding the wire properly. For the antenna which is just a 3' small gauge wire coming from the module, I just ran it behind the dash and towards the drivers door. Seems to be fine for now as I'm not sure what else to do with it since it's not long enough to run it up the a pillar and across the top of the windshield like I wanted to do. for the excess wires that I didn't use I decided to wrap them up with electrical tape and tape them out of the way behind the dash. I did the same with the excess length of wire as well. I could have cut the wires I didn't use and maybe I will down the road, but I didn't want to do it so soon after the install in case I needed something later. Edit* Here are 2 new images, one of the LED placement ![]() and one of the Module placement. ![]() I also added extra wire I had and used a butt connector to the stock antenna wire. I then ran the now extra long antenna up the drivers side pillar, across the roof panel (where the LED is) and then down the passenger side A pillar. This should allow for much better range with the fob's.
Awesome!
![]() Drives: 2008 Yaris Join Date: Nov 2010
Hi tmontague,
I just installed the 211vh and got everything working except the parking light before I saw your post tonight. Just need to double check with you before I attempt to fix the issue with a paper clip. Did you un-tap the white wire (H1/10) from the headlight switch connector and then used a paper clip to ground it directly from the back of the (H1/10) pin hole to the back of H1/3 pin hole on the viper module connector? If that's the case then I will try to fix it the way you did. Thanks you! |
#4 | |
I just installed the new module I was sent since the original one was not grounding the parking lights. The new one also has the same problem unfortunately. Either it's plain bad luck and Vipers quality is turning into crap (CTScott had eluded to this in his experience) or the other possibility is that for some reason I have to tap into the parking light positive wire and not negative. With the way the wires are set up in my stock connector the negative wire should work fine as others have installed it that way.
f10167, keep me updated with your experience with it and if your wiring is good (tested by the paperclip) then I have a feeling that we have to tap into the positive wire as I don't think it's a coincidence that 3 modules all have the same problem
*Problem solved*
The reason the parking lights do not work is because the fuse that is located in the module is set up in a positive wire position and not the negative wire position you need to move it to. I have updated the DIY on my original post so check there on how to do this. The parking lights are now flashing!
#7 | |
My parking light and the headlight buzzing sound came right up with the paper clip so now I'm sure that the viper module is definitely defected as I have already put the flash light fuse to negative terminal. I have already contact the seller and the replacement module is on the way.Thanks for the feedback. |
hmm, then your wiring is definitely fine and the taps are good. If you've moved the fuse to either position and still have no parking lights then I would assume the module is at fault for not grounding the parking lights. Keep this thread updated with how the new module works out for you.
#9 | |
Glad to hear it worked for you. You definitely can't beat $25. The install should take about an hour now with the diy.
![]() Drives: 2008 Yaris LB Join Date: Sep 2015
Hey, i just purchased 211hv for my 08 yaris, and i found your installation guide. I read it several times, but still not sure about some steps. When you talk about 3 ground wires what color are they or which pin (h1/1, h1/2 etc). also can you tell me which wires did you not use at all? I would like to get all of the functions working, but from what i understand not all wires have to be connected. So far I know where connectors h1/1, 7, 9, 10, 11, 12, and 15 go. Also i know connectors 13, 14, and 18 are not in use. Is this correct so far? Thanks in advance
I just realized that I forgot to add one of most important images when I uploaded the DIY
I fixed it and added the chart of what wires are used and which ones are needed for all of the functions to work. The chart shows 4 ground wires but keep in mind 2 of them (violet and violet/black) are both merging into one wire after the fuse from the module. So in total you're only grounding 3 wires. Let me know if you have any other Q's
Awesome. That helps a lot. I will be installing it tomorrow, and I'll let you know if I have any question. Thank you!!
#14 |
Just installed it. Took about an hour with your DIY to install and some more time to clean up the wiring. Everything works great. Thank you again.
#15 |
Not a problem, glad it worked out for you
#16 |
Drives: '12 Sedan Join Date: May 2018
Hello, I am looking to install a keyless entry system in a '12 sedan. It has power locks already. Glad to find this DIY but for some reason none of the pictures are showing...
#17 |
Looks like I still have the pics, I'll throw them back up later today, it makes the install very straight forwards
#18 |
Drives: charleymills Join Date: Aug 2018
hi - I'm not seeing the pics. Any chance you still have them?
| 2014 Keyless Entry Install Question | GMRelkin | DIY / Maintenance / Service | 4 | 03-10-2017 12:26 AM |
| keyless entry issues | azamora | General Yaris / Vitz Discussion | 0 | 10-29-2013 09:29 PM |
| Keyless Entry Remotes are dead... now what? | Zanutto | General Yaris / Vitz Discussion | 7 | 01-11-2012 06:17 AM |
| Keyless Entry | BLKYRSSDN | In Car Entertainment + Electronics (audio / video / alarm) | 44 | 09-16-2007 11:27 PM |
| DIY KEYLESS ENTRY on Power Liftback? | TC-LIFTBACK | DIY / Maintenance / Service | 0 | 08-23-2006 10:57 AM |
