#73 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
For those of you with a auto transmission: If you use a Xd harness you won't need this step. If you used the Corolla harness pin#57 needs to be moved to #58. This is for the Sl/Slu+ solenoid.
#74 |
Data doesn't lie
This is the lock on the main harness connector(C20). You have to pop this grey tab out about 1mm before you can release the pins.
#75 |
Data doesn't lie
Next you need to slide a small pin into the pin release hole. Pull on the white #57 wire and wiggle a bit until it slides out.
#76 |
Data doesn't lie
Pop out the little rubber seal in pin location #58, and slide the wire in until it clicks. Install the rubber seal back into #57, then push the grey lock tab back in.
FYI: This pin removal/install procedure is the same for the ABS module plug, in case you used a Xd trans with no speed sensor. |
#77 |
Data doesn't lie
This is the last of the auto trans related wiring. Because the Corolla/Xd have different ground circuits than the Yaris for the Sl solenoid, you need to open the trans harness about 8" from the plug and cut the blue wire at pin #9. Pull the wire out of the harness while still connected to the connector and attatch a eyelet, the ground the wire to the trans case here.
#78 |
Data doesn't lie
Now that all the wiring is complete, lets be sure the ECM is happy........yep, time to charge the a/c and take it for a drive...
#79 |
YAAAAAY!
Congrats.... Only reason I am upset is because you have a CamCon that you were going to tune with the 1nz and share a mild tune with me.................
#80 |
Data doesn't lie
Thanks man.
Haha, Im sorry about the tune.....I never had a chance to install the Camcon either, life threw me a lemon and I had to make a batch of oh-so-sweet lemonade! On a side note.....holy crap this car is a BLAST!
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-28-2016 at 11:43 AM. |
#81 |
so was the faulty trans ground the reaosn for the previous CEL that was regarding the torque converter?
#82 |
Data doesn't lie
It wasnt a faulty ground, just a difference in how the Corolla/xd is wired inside the transmission valvebody...2 wire changes and done.
#83 |
I see, but that wire you just grounded above was the reason for the torque converter cel?
#84 |
Data doesn't lie
That's correct
#85 |
Why, oh why, are you holding out on the first start and test drive vid!
#86 |
Data doesn't lie
Ive edited the videos together up to this point, I need to do a test drive video along with some footage of this weekends autocross.
#87 |
![]() ![]() ![]() Drives: 2011 Yaris RS 5 door 5 spd Join Date: Aug 2012
Im curious to see your time differences in autocross between the 1nz and 2zr... Ill be watching this closely. Good job btw, i bet a lot of people have been putting diesel fuel in there yaris' to justify an engine swap... Or maybe thats just me. :p
![]() TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges... |
#88 | |
#89 |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
I wonder...is there a big weight difference between the 2 engines?
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#90 |
Data doesn't lie
On every engine Ive owned Ive had one of these guys. It never hurts to monitor your oil pressure especially when you push the engine like we do. This is a decent quality electronic gauge with a sender(not the nylon tube). Reasonably priced at $84. I normally remove the stock "dummy light" oil pressure switch and install the gauge sensor in that port. You'll also need Auto Meter adaptor #2269 because the block port is BSPT vs most oil pressure senders are NPT.
www.Facebook.com/ArmstrongRacingPage www.youtube.com/c/ArmstrongRacing www.instagram.com/Armstrong_Racing http://www.wheelwell.com/profile/55f...35ac4a/garage/ Last edited by ArmstrongRacing; 01-30-2016 at 12:12 AM. |
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 12:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 06:56 PM |
