Old 02-05-2016, 10:20 AM   #145
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
The 2zr uses a 5 rib belt vs the 1nz 3 rib. If there is a way to swap pulleys you can use the 1nz alternator and a/c compressor....
Old 02-05-2016, 11:44 AM   #146
tmontague
tmontague's Avatar
Armstrong, how'd you know exactly what pins were what on the Corolla harness so that you could put them the correct way when you moved all the pins to match the fuse box? I'm assuming you had the electrical diagrams from a Corolla?
Old 02-05-2016, 12:04 PM   #147
CoryM
Drives: 2009 5-door, 5-speed
I've not looked at the setup, but it may be possible to use the 3 rib belt on the 5 rib pulley. So long as both belts are "PK" belts, the rib spacing is the same. You'd still have to ensure things are lined up nicely.
Cheers.
Old 02-05-2016, 02:06 PM   #148
ArmstrongRacing
Data doesn't lie
Correct. I have ALL of the diagrams for the Yaris, Corolla, and Xd.....And I spent about a week studying and creating wiring instructions for myself...it was not an easy task.
Old 02-05-2016, 06:23 PM   #149
ArmstrongRacing
Data doesn't lie
When you get your oil pressure gauge hooked up, you will notice it idles at about 12psi. Dont be alarmed, the 2zr has completely different oil pressure specs from the 1nz.
3.6psi or more at idle
22-58psi at 3000rpm
Old 02-05-2016, 06:58 PM   #150
beaker
Drives: 07 Yaris 3 door
The alternator shouldn't be a problem, just need an impact wrench to get the pulley off I would imagine, unless it's pressed on. The AC compressor would probably be a little tricky, as they usually require specialty pullers that the average person wouldn't have in their tool box.
I know the water pump pulley is a press on, so changing the 2zrfe to the 1nz 3 rib would probably not work, and I bet the diameter on the water pump shafts aren't the same. Then there's the crank pulley....
Would be better to just source 2zrfe accessories.
beaker is offline   Reply With Quote
Old 02-06-2016, 09:50 AM   #151
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
Here in SA we only have the 1.3l and the 1.8 T-Sport. Originally I wanted to swap to 1.5 but this is definitely looking like a good deal. I am just wondering Armstrong, do you think if I could find a 1.8 T-Sport I could use all the parts from it to do a direct swap? We don't have Scion's here and importing the bits would be costly. But I have to do it, I raced a Corolla last night and just-just lost. It has really sparked interest in this swap :D
MedMantle is offline   Reply With Quote
Old 02-06-2016, 10:23 AM   #152
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
If you can get a Yaris T-sport (1.8L), it should all be bolt-on. But why not just buy a 1.8L?
Old 02-06-2016, 10:31 AM   #153
MedMantle
MedMantle's Avatar
My sister owned one and it was great as far as I can remember but I love my 4 door, my soul is in this car haha I am also so sure it should all just bolt on. I'm hoping to find a scrapped one, maybe I'm lucky and get the 6-speed box as well :D
Old 02-06-2016, 12:41 PM   #154
CrankyOldMan
You've got a C154. The 6-speed on the 2009 T-Sport from Europe is the EC67. You have to have all the supporting hydraulic lines and mounts to make it fit, since it's a completely different family of gearboxes. Probably need the drive shafts and hubs, too. Now that I think of it, I don't know that the C154 will bolt up to the 2ZR. I would assume it can, since the 1NZ bolts to the C50. Probably best you start another thread for that discussion. =)
Old 02-06-2016, 01:09 PM   #155
ArmstrongRacing
Data doesn't lie
My sister owned one and it was great as far as I can remember but I love my 4 door...
I also have a sedan, a TRD edition with power everything, so I feel the same about keeping the car. Your swap will be easy just like ours being that you have the Tsport there. Wrecked Yaris' are hard to come by though so you may have to search for a used engine from another 2zr equipped car, and then get the smaller items new from Toyota like I did.
Old 02-06-2016, 05:14 PM   #156
MedMantle
MedMantle's Avatar
I'm gonna try and check out a T-Sport if I can find one on the road. The bits I'll need off it would probably be equivalent to the ones on the Scion! I'll do some research! And yeah, to find wrecked T-Sports isn't proving to be very successful haha
Stoked, I've got something to ponder on and CrankyOldMan, you are correct. I don't want to make work for myself so I'll stick to the engine swap.. for now :P
Old 02-07-2016, 11:57 PM   #157
ArmstrongRacing
Data doesn't lie
I finally got my GoPro video up!
https://youtu.be/zk9bbkm4WQY
Old 02-08-2016, 04:58 AM   #158
tmontague
tmontague's Avatar
Damn, that sounds nice. Good driving too!
Old 02-08-2016, 08:38 AM   #159
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Wow that thing really rips through the first couple gears
Old 02-08-2016, 09:08 AM   #160
CrankyOldMan
Nice recovery over the finish!
Old 02-08-2016, 03:35 PM   #161
ArmstrongRacing
Data doesn't lie
Yeah this car is a blast....I have another autocross this Sunday, and the weather looks great so I'll get to use all the power. A friend that drives a Fiesta ST will be driving the car too to give some feedback.
Old 02-11-2016, 12:50 PM   #162
ArmstrongRacing
Data doesn't lie
Decals!
unusual engine swap CoryM Performance Modifications 26 10-09-2015 12:17 AM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
Scion/Yaris engine swap mrrock Performance Modifications 1 03-02-2011 06:56 PM
