Old 02-16-2016, 04:02 PM   #1
crazylegs
Drives: 2007 Yaris
Are 13s possible with a 1nZ-Fe
Cold Air Intake
1zz-fe TB
1zz-fe manifold
Cams
Header
full exhaust
sticky rubber
80 shot of nitrous direct port
im thinking on an ATX you'd still be lucky to break into the 14s, but what about an MTX assuming your a good driver
crazylegs is offline   Reply With Quote
Old 02-17-2016, 01:32 PM   #2
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Not a chance.
The Micro Image Yaris was running 12.80s at 107 with a fully built engine and turbo making like 300+ hp. Bolt-ons, cam, and nitrous will likely get you into the low 15s if I were to guess if you were a good driver.
https://www.youtube.com/watch?v=HszS1X-wD6Q
Old 02-17-2016, 08:36 PM   #3
crazylegs
Drives: 2007 Yaris
yeah thats what i figured. i just went and picked up a mx-3 with a klze swap as my next project car and i'll just keep the yaris as my daily driver.
Old 02-17-2016, 09:57 PM   #4
Dragonslayer182
Teal Squealer
Drives: 07 Yaris Sedan
https://www.youtube.com/watch?v=bHkZP2e8se8
Dragonslayer182 is offline   Reply With Quote
Old 02-17-2016, 11:10 PM   #5
crazylegs
Drives: 2007 Yaris
yeah that has pistons and rods done does it not. i know you can break into the 12s with a built bottom end and the boost or spray. but i was just curious about the above mod list which might get you 110-120whp N/A and 190-200whp on the bottle. i think that should break into the 13s with an MTX driven by a good driver. the power to weight ratio is there that's for sure. i'm just going to keep it a bone stock daily driver until i have to do something to the bottom end then we will see.
1nz Disassembly & Reassembly. EchoLaQua Forced Induction Forum 0 06-19-2015 12:17 PM
pittsburgh 13's djhuddy2442 Tracking, Racing, Auto-X Forum 0 10-29-2014 10:05 AM
The Toyota 1NZ Enthusiast's Garage on Facebook fnkngrv Off-topic / Other Cars / Everything else Discussions 3 04-07-2014 02:55 PM
1NZ / 2NZ Transmission Compatibility & Aftermarket 2NZ Rods jtw11 Performance Modifications 8 09-03-2013 02:49 PM
1NZ port & polish ChinoCharles Performance Modifications 75 06-01-2009 07:39 PM
