Old 02-19-2016, 03:13 PM   #1
Gagi
Gagi's Avatar
Drives: Yaris 1.33 vvti 2015
Foot-light assembly on Yaris 2015 (Europe)
I discovered some "empty" connectors in my Yaris and found out that they serve for higher package in equipment as "No.1 interior light assembly", foot light. I don't know for the other models, but most of them should have this ability.
Conditions to turn them on: unlock, door open, key removal...
They work exactly the same as the Map light with exception of no switch to manually turn them on or off.
Ordered two from Toyota dealer, perfect fit.
Not the cheapest LED on the market but they really changed the appearance.
Gagi is offline   Reply With Quote
Old 02-19-2016, 07:46 PM   #2
apmatzen
apmatzen's Avatar
Drives: Toyota Yaris 2015 1.0VVT-i T2
What's the price on such a pair?
Toyota Yaris 1.0VVT-i T2
apmatzen is offline   Reply With Quote
Old 02-20-2016, 01:01 AM   #3
Gagi
Gagi's Avatar
13.5 € each.
Old 02-20-2016, 04:43 AM   #4
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Here you go APmatzen.
http://www.erabiler.dk/product/toyota-81080-0d010
I will get some for my yaris too, there isnt much cabin light in the yaris
stykerdk is offline   Reply With Quote
Old 02-20-2016, 05:35 AM   #5
apmatzen
apmatzen's Avatar
Styrkerdk, I already found that, but thanks.
There is also one for the glove box...
Think I'll get that one also. (81260)
File Type: png Skærmbillede 2016-02-20 kl. 10.18.57.png (29.6 KB, 673 views)
Old 02-20-2016, 10:22 AM   #6
kr1
Show & Go
kr1's Avatar
Drives: Yaris HSD -12, GT86 -12
Nice, where was that connector wire hidden ?
kr1 is offline   Reply With Quote
Old 02-20-2016, 10:53 AM   #7
apmatzen
apmatzen's Avatar
Haven't found it yet...and the weather isn't very good for standing outside right now...sorry.
But maybe every 2012-2015 Yaris has it? Don't know.
Old 02-20-2016, 12:29 PM   #8
Gagi
Gagi's Avatar
On the passenger side, when the glove box is removed, cable should be in the right corner together with other cabling joined with the white tape that you will have to remove.
On the drivers side, when a two bolts under knee area are unscrewed and cover removed, cable and connector are joined with the white tape together with cable that goes on TPMS reset switch.
According to the Toyota's new features bulletin, models from 2014-07 have no Glove box light ability, and I can confirm that for myself. There is no connection on mine.
Models from 2011-06 until 2014-07 should have both interior foot light and glove box installations.
Old 02-20-2016, 01:13 PM   #9
Gagi
Gagi's Avatar
Don't rush with glove box... I was sad to find there is no connector...
Old 02-20-2016, 01:46 PM   #10
apmatzen
apmatzen's Avatar
Thanks Gagi, good to know.
Old 02-20-2016, 07:02 PM   #11
ucsmfu
Drives: yaris le
This doesn't apply in 2012 north american Yaris models right ?
ucsmfu is offline   Reply With Quote
Old 02-20-2016, 07:25 PM   #12
Gagi
Gagi's Avatar
Check if there is a place for LED on passenger side lower trim. You will see if there is a cone. Or you can remove glove box. Fully open it, and pull it horizontally towards yourself. Once removed you should see is there a place on plastic cover and most important is there any spare connector. You can check then with multimeter is there any power on it.
Old 02-22-2016, 10:51 AM   #13
Turnby
Drives: 2014 Yaris Icon VVT-I
Should the glovebox light always be on? Think mine in my 2014 model is on when closed
Turnby is offline   Reply With Quote
Old 02-22-2016, 03:39 PM   #14
Gagi
Gagi's Avatar
Yes it should be always on, when panel lights are on.
Old 02-27-2016, 08:28 AM   #15
Turnby
After seeing this thread, tried it out on my 2014 Icon+ VVT-i and all went as planned.
Bought 2 x 'Lamp Assy, Interior Illuminati' 81080-0D010 from local Arnold Clark (total £18)
Going to get some aluminium tape as suggested to brighten them. Cheers!
Old 04-17-2016, 04:46 PM   #16
karloslatynos
karloslatynos's Avatar
Drives: 2012 Yaris TR 1.33 VVT-i Man
In my 2012 beauty is there
karloslatynos is offline   Reply With Quote
Old 05-20-2016, 06:50 AM   #17
ColinPillai
i ordered both and it works great part number is correct. i am all the way in South Africa lol
ColinPillai is offline   Reply With Quote
Old 10-30-2016, 04:24 AM   #18
ColinPillai
hi where did you find the glovebox connector?
i am having troubles locating it :(
please help.
Toyota Yaris Battery Light On - Repair gabo General Yaris / Vitz Discussion 1 08-24-2011 08:21 AM
Yaris AUX (auxillary) Stereo Jack assembly 2008 Yaris omendt Items for Sale by private party 0 07-13-2010 10:46 AM
Help: Water/Moisture Entered Fog Light Assembly bigsky2 DIY / Maintenance / Service 10 12-19-2006 01:10 AM
