Old 02-29-2016, 12:52 AM   #37
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Nice..
Do you use the same engine mounts on the right side as the one in the Yaris? I'm guessing the driver side and underneath are the same because you're using the Yaris gearbox. Also I have a manual Yaris so i have to change the ecu and harness right? Sorry for the stupid questions.
Old 02-29-2016, 06:34 AM   #38
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
The right side engine mount is from a Scion XD. The middle rear and LH mounts are the same. For a manual, you would need the harness and ECU from a manual XD.
brushforhire is offline   Reply With Quote
Old 02-29-2016, 10:15 PM   #39
brushforhire
I ordered the RPM header and midpipe. I finally caved. LoL
Old 02-29-2016, 10:36 PM   #40
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Haha awesome, I did too!
ArmstrongRacing is offline   Reply With Quote
Old 02-29-2016, 11:32 PM   #41
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I've got one on my wish list. I'm sure RPM and FastScions appreciate the surge in business!
Old 03-01-2016, 06:46 PM   #42
brushforhire
For sure. I did some digging and found a 5% off coupon code on their facebook page. "tax"
I had to order a few random parts while I am in there doing this. A RH rad support, and lower rad tie bar. Both a little bent from when I hit a snow bank. Not to noticeable, but it will drive me bananas knowing that they are bent.
Coilovers arrived. Will work on those while I wait for other parts. Gotta get some of the suspension stuff straighten out while I have it all apart before I throw the engine back in.
Old 03-08-2016, 03:39 PM   #43
brushforhire
Project is still moving along, just very, very slowly. I had to order a number of random parts to get going again. For some reason the junkyard had took the flexplate off, and I didn't realize there was a plate that was supposed to behind and in front of it. On backorder, or course. The RPM exhaust is gonna be another two weeks.
On the bright side, I am taking the time to attack some of the rust on random parts.
Old 03-08-2016, 04:04 PM   #44
CrankyOldMan
I'm probably 6 weeks out on mine, trying to pick up smaller components along the way. I've already got the wire harness. Engine ECM, MAF and intake are next on the list.
Old 03-09-2016, 02:02 PM   #45
3cyltrbo
I'll be watching that (because I believe you would be the first manual transmission swap to be properly documented?)
Will
3cyltrbo is offline   Reply With Quote
Old 03-09-2016, 05:57 PM   #46
brushforhire
Quick pic of my front swaybar repaint. It was rusted really badly, so I just took it out and took the angle grinder to it and then primed and repainted. Gonna shoot a couple coats of clear coat, and should be good to go.
Old 03-09-2016, 06:59 PM   #47
CrankyOldMan
That's the plan! =) I don't know if I'll start a thread before I have all the gubbins, because that can be a disaster if I don't get everything and have to abandon the project.
Old 03-14-2016, 10:16 PM   #48
brushforhire
A couple quick pics. I have a lot more I am gonna organize to try and provide a more complete guide.
Old 03-15-2016, 12:03 AM   #49
ArmstrongRacing
Data doesn't lie
Looking good!
Old 03-20-2016, 09:06 PM   #50
brushforhire
Speed sensor wiring
Here is my rundown of the speed sensor.
The XD harness does not have the speed sensor from the Yaris tranny. The harness plug in the fuse box has the empty spots for it.
The speed sensor on the transmission
The sensor plug:
Use a pin to remove the wires, gotta kinda fiddle with it.
The Three wires you want to remove from the yaris plug:
Where they go in the XD harness plug:
While you at the plug on the XD harness, remove the MAF power wire. It is the black with silver markings.
Old 03-20-2016, 09:13 PM   #51
brushforhire
Ground the transmission wire
You will need to ground the torque solenoid wire to the transmission.
EDIT: UPDATED PROCESS FOR XD HARNESS. ALL YOU NEED TO DO IS ADD A PIN/WIRE TO THE EMPTY PIN LOCATION 9, NEXT TO THE BLUE WIRE IN SPOT 10, SO YOU CAN GROUND IT OUT. REALLY EASY.
EDIT: NO NEED TO DO THIS PART!! Pull the loom and tape back from the transmission harness.
EDIT: LEAVE THIS WIRE ATTACHED!!! This is the blue wire you want from the upper plug:
THIS BLUE WIRE IS PIN 10. YOU NEED TO ADD A WIRE/PIN FROM YOUR OLD YARIS HARNESS TO PIN LOCATION 9, WHICH IS EMPTY ON THE XD HARNESS. THAT IS WHAT YOU WILL THEN GROUND TO THE TRANSMISSION.
THIS IS WHAT PIN LOCATION 9 SHOULD LOOK LIKE, NOT 10. IN THE SPOT THAT THE BLACK RUBBER PLUG IS IN, NEXT TO THE BLUE WIRE. I grounded it to this point on the case. The hole was not threaded on my trans, so I used a 6MM x 1.00 tap and ran a bolt in there to ground it.
Old 03-20-2016, 09:22 PM   #52
brushforhire
Flexplate Fun
I am posting this, because my junkyard thought it was easier to remove the flexplate and spacers and throw them away, instead of leaving them on. I bought a flexplate on put it on, without realizing that there were supposed to be spacers. Ugh.
The supplies:
Inner spacer:
Plate and outer spacer:
The bolts that hold the plate on, put a drop or two of blue threadlock on each bolt. They get torqued down to 65 ft lb.
Old 03-20-2016, 09:53 PM   #53
ArmstrongRacing
Data doesn't lie
Good work man!
(for those that use a corolla harness don't forget to swap the SL solenoid pin at the ecm also!)
Old 03-20-2016, 10:01 PM   #54
tmontague
tmontague's Avatar
Thanks a ton for taking pictures and explaining what wires need to b taken care of. Makes it much easier for future swaps.
Keep it up!
Yaris Motor Swap Thread *Read before posting swap threads* Sabretooth Performance Modifications 219 06-10-2025 03:58 PM
1nzfe throttle body swap and fitment questions EchoBob02 Performance Modifications 14 05-01-2014 09:02 AM
60/40 to Bench Seat Swap Issue CTScott Cosmetic Modifications (Exterior/Interior) 24 11-26-2012 03:45 PM
FS: COMPLETE 2ZZ SWAP!!!! (SOCAL) AdeJong 03 Items for Sale by private party 4 04-06-2010 12:25 AM
Gauge Cluster Swap, other interior swap questions. Adrenalingirl_K In Car Entertainment + Electronics (audio / video / alarm) 4 04-09-2009 04:32 AM
