![]() Drives: 2008 Toyota Yaris Hatchback Join Date: Apr 2016
Noise From ABS when Braking + ABS & (!) Light On - Please Help
Hi guys,
I have a 2008 Toyota Yaris that is causing me a lot of trouble, and money with the ABS. Since December, the ABS has been causing me a lot of problems with this car. Sometimes when I brake there's a loud grinding noise coming from the ABS. Usually after this occurs the ABS & "!" Lights will come on signally that the ABS is turned off. Also, when it makes this noise the car doesn't break as smooth or rapid, it kind of slowly creeps forward while making the noise. The noise only occurs when the lights AREN'T on. You can see a link to the video I made at the bottom to see the problem for yourself. I have been to the mechanic 3 different times. I've had a bunch of new work done to the brakes themselves so I know thats not the problem. I've gotten a new ABS sensor. And today I just got back from the mechanic after he installed a new bearing, just to drive back home to find the ABS making the same noise and problem. Does anyone know what I should do? ANY suggestions help. Thanks! Here's the link to the video: https://www.youtube.com/watch?v=gf26ea7DzP4 |
Chances are the sensors are shot causing the ABS to intermittently work or not work properly. The temporary solution is to pull the fuse and just drive with it off for now.
There is a thread on this forum that highlights how to remove the senors and then clean and apply some dielectric grease in them to stop the corrosion. Essentially it is a poor design from Toyota that allows the sensors to becomes contaminated and corroded. Buying oem sensors are pricey so I'd recommend going with aftermarket or just driving without them. If they are salvageable, cleaning them and greasing them may improve your issue
#3 | |
| abs light on | brieghne | DIY / Maintenance / Service | 1 | 02-23-2012 08:30 AM |
| ABS light on.... Do'h! | BURRITO | General Yaris / Vitz Discussion | 3 | 11-27-2011 08:02 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
| Noise when braking | hystria | DIY / Maintenance / Service | 9 | 05-02-2007 09:28 AM |
| ABS....Again~~ | MeggiemobileSFLA | DIY / Maintenance / Service | 11 | 04-03-2007 09:12 AM |
