Old 05-10-2016, 02:10 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Free: Half set used OEM Brake Pads.
GONE
Did a brake job on someone's '07 Yaris and now have two good pads left. They are used but have more than half their life left. If anyone is doing a brake job and need two good pads just pay shipping or can pick them up free. These are genuine Toyota pads.
Old 05-10-2016, 04:00 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
lol ...I must have a bin full of outside pads from doing brake jobs on Yaris , never will run out for myself haha
Typical problem with yaris it kills the inside pads if one does not drive the crap out of there car .
Old 05-10-2016, 05:17 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Is it typical to go +65k on the original brakes? I'm up over 65k miles on my car now and they keep telling me my brakes are good. I don't recall going that long on original brakes in the few other cars I've owned.
Old 05-10-2016, 05:20 PM   #4
Bluevitz-rs
That's exactly what it was. The one inside on the driver was metal to metal. They were only there so I could assess what they needed and I had to drive them home because I couldn't let them leave LOL.
Old 05-10-2016, 05:36 PM   #5
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I had 87k on mine when I changed the brake pads. The outside ones were fine but the insides were getting thin. I probably could have gotten another 20k out of them but both of my rotors were warped and it was driving me crazy.
Old 05-10-2016, 06:05 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Other option is if u have the knowledge in how to service brakes one can always flip pads, outside to inside and get more life out of ur pads.
But I find if ur hard on ur brakes this issue is not as common.
Sent from my ONE A2005 using Tapatalk
Old 05-10-2016, 06:08 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Ya I can get 80 km from front, I'm on my second set but still on original rear shoes and drums and I'm at 172333km now.
Old 05-10-2016, 06:45 PM   #8
ern-diz
ern-diz's Avatar
Love it.
Old 05-10-2016, 08:13 PM   #9
Did my rear shoes for the first time this year at 275,555 kms. Lots of meat left on the bottom of shoes, tops where gone. On my 4th set of front pads.
Old 05-10-2016, 08:24 PM   #10
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Wow that's really good I got some left gone drive it till it makes grind noise lol
Old 05-10-2016, 08:27 PM   #11
sickpuppy1
Drives: 2010 Yaris Sedan
I replaced my fronts at 97000 miles. Still had a surprising amount of pad left, both inner and outer pads.
Old 05-11-2016, 04:14 AM   #12
yariseggvvti
Drives: Yaris Hatchieback
brake pad replacement
i had mine replace all around front pad, rotors and rear shoes in 100500 miles. my tech said still have 1/4 inch life to go. i had replace stop tech brake line since 35k.
yariseggvvti is offline   Reply With Quote
Old 06-14-2016, 09:27 PM   #13
Tapokata
Drives: 2009 Yaris
Original breaks with plenty of life left in them on my 09 HB, at 154K miles.
Most of the mileage was long distance highway driving (I had a 180 mile round trip commute to work each day)- so you really can't wear out what you don't use.
Tapokata is offline   Reply With Quote
Old 07-03-2016, 12:16 PM   #14
SirDigby
Drives: 2007 yaris 3 door
you should never have to replace the rear shoes unless they become contaminated. my last civic had factory oem shoes when I sold it at 338,000mi.(543,960km) I had purchased shoes twice, but when removing drums there was plenty of friction material; so clean and adjust but never replaced...
also, car was driven in the mountains it's entire life. lots of brake use....
Old 07-03-2016, 12:23 PM   #15
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Never...what world are you living in, u got lucky and yes clean and adjust can only make it last that much longer also keep in mind weather, climate.
I got about 1 mm left in the rear have new shoes in my tool box lol just lazy to replace.
Sent from my ONEPLUS A3000 using Tapatalk
Old 07-04-2016, 11:24 PM   #16
johnny_vitz
Drives: 2005 Toyota Echo
you should never have to replace the rear shoes unless they become contaminated...
Shoes wear out just like pads, just not as quickly. They typically last twice as long. The only way what you are saying is even possible (and would not likely ever happen) is if both wheel cylinders were completely siezed and not applying the shoes anymore.
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 07-29-2016, 11:07 AM   #17
srm73
Drives: 2007 Toyota Yaris
Originally Posted by Bluevitz-rs
Did a brake job on someone's '07 Yaris and now have two good pads left. They are used but have more than half their life left. If anyone is doing a brake job and need two good pads just pay shipping or can pick them up free. These are genuine Toyota pads..
I can take them if you still have them. My area code is L9T0J7 Milton ON Canada. What part of ON you are from?
srm73 is offline   Reply With Quote
Old 07-29-2016, 11:13 AM   #18
^ Courtice
