Old 05-16-2016, 01:07 PM   #19
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
I don't think you can reflash the ECU on a Toyota.
brushforhire is offline   Reply With Quote
Old 05-17-2016, 10:40 AM   #20
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
The original Toyota ECU is locked down tight, and CANNOT be reflashed. Lots of people have tried.
You can install a stand-alone ECU, like an AEM EMS-4, but unless you go the forced induction route, you woun't be seeing any real big gains.
Old 05-17-2016, 12:51 PM   #21
marion2
Drives: Yaris Sedan YRS
How about if I choose to use a stand-alone ECU like Adaptronic will it be beneficial on a stock 1nz engine? Not gonna go on a forced induction route but planning to pursue it's NA potential. Will it also be a reliable one with just some small kicks?
marion2 is offline   Reply With Quote
Old 05-17-2016, 01:23 PM   #22
rabbito
rabbito's Avatar
you cannot reflash them..we already tried..now i am running E85 piggy back...so far running good without an issue
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
Old 05-20-2016, 01:17 AM   #23
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
There is actually a new player in the industry that is saying they have cracked the 07 and newer ECU for multiple models and can flash them. The name however currently escapes me. I do recall seeing that they have been pretty big in the Mazda scene for a while.
Sent from m-o-b-i-l-e
Old 05-21-2016, 05:37 AM   #24
rabbito
rabbito's Avatar
rather pay for cheap piggyback than doing all them hassles.. 😐
engine, improve, performance, tweak, vitz rs 1.5 2001
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
FS: Used Beatrush Engine Roll Stopper FunctionSpec Items for Sale by private party 7 06-02-2010 02:38 PM
engine swap update Adriaan Canada 5 03-03-2009 07:21 PM
Info regarding Engine change. sheraz2000 General Yaris / Vitz Discussion 5 01-08-2009 01:51 AM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
