#37 | |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
lubing
#38 |
![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
update
I uses this on slave cylinder and inside car 20 days no squeek at all.
https://www.tetrosyl.com/tetconnect/..._spray/DTT400- I also remove the boot rubber and spray inside |
#39 |
ok Gents still a month no squeak clutch pedal smooth not feeling hard / heavy.
TT did the job highly recommended. |
#40 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I have had this sqeak for a few years. Its definitely the clutch fork pivot. I have removed the slave and lubed it to be sure its good and the noise did not go away, suggesting the only other friction that can be causing that type of noise.
The idea of spraying willy nilly towards my clutch to get to the pivot does not sit well with me.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#41 |
![]() ![]() Drives: 2010 Yaris hatch Join Date: Mar 2011
For a while, I thought my clutch was squeaking too, but then realized it was my SEAT! When I pushed the clutch, my body of course was slightly pushed back in the seat, and the seat made a very slight squeak noise. I guess I can't oil the seat! :)
"I like the dreams of the future better than the history of the past" - Patrick Henry |
#42 |
You need to identify the source it can be the pedal
#43 |
Grease it
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 03:59 AM |
| Way to shorten distance on clutch pedal? | kac | Performance Modifications | 2 | 07-23-2009 06:42 PM |
| squeaky clutch | TickleTimeTim | DIY / Maintenance / Service | 4 | 04-28-2009 11:36 AM |
| Car/engine shake when releasing the clutch pedal | hystria | DIY / Maintenance / Service | 16 | 07-22-2007 07:56 PM |
| Hard clutch pedal ? | hystria | General Yaris / Vitz Discussion | 5 | 05-11-2007 06:12 AM |
