#307 |
2007, just over 57k miles.
Other than having the rack & pinion replaced at 40k and the clear coat on the bumpers re-sprayed, it's been smooth sailing. |
#308 |
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
Well at 57k it's barely broken in ;) Did you drive over a curb or why did the r&p have to be replaced?
#309 |
The car was involved in a minor fender bender early on when a friend didn't realize I was parked behind her and backed into me. It was a low to no speed impact and I had everything inspected/repaired professionally, so not sure that caused it, but don't know what else might have. Maybe just a factory dud? I opted for the extended warranty, so luckily it only cost me the $50 deductible to have it all replaced by the stealership.
#310 |
08 2dr HB
73,300 miles Bought new in March 2008 no repairs, only oil changes - not counting the recent accident 3-4-18, 92k and still running fine.
- The Black Ship Yaris - Last edited by blktiger60; 03-04-2018 at 11:25 PM. |
#311 |
![]() Drives: 07 yaris rs Join Date: Jun 2011
2007 yaris rs 5 door 225,000 km, no major problems, I had an ABS light come on 2 years ago during the spring. Cleaned the connector and it went away.
put on a tooter intake manifold and a 1zz throttle body about 20,00km ago, only issue there is if I don't let the car warm up sufficiently the throttle body gives an over current CEL and limits the rpm to 2000, and that only happens when its below -25. this car has been dead reliable and couldn't be happier with it. |
#312 |
yak
Drives: 2007 5 dr yaris Join Date: Jan 2009
2007 5Dr Hatch milage
357km
drive it like I stole it every day routine maintenance, oil, plugs, air filter cleaning (CAI) replaced serpentine belt at 265km |
#313 |
![]() Drives: 2007 Yaris Hatchback Join Date: Apr 2013
2007 Yaris 2dr. Hatchback CE
No issues besides regular maintenance (1 headlight bulb, brakes, tires filters, oil) 165,000 miles and going. Black mica |
#314 |
![]() ![]() Drives: 2007 Toyota Yaris Join Date: Nov 2015
2006 hatch
162,000km At the dealership right now and the camshaft gear needs to be replaced. Fffaawwwww-k |
#315 |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
2006 Hatchback, 5 door, 1KR-FE engine.
100,000 miles. Water pump went bad at 65,000 miles. Made a lot of noise. Alternator failed at 88,000 miles. Faulty voltage regulator. Drove it around for weeks. Other than that. A few tyres, brake pads, a battery and an exhaust a bulb or two and servicing. I really can't complain. I drive it like i stole it and it takes me all over the country. |
#316 |
![]() Drives: grey Join Date: Jul 2015
2008 4 door
168,698 miles and counting No repairs besides recharging the AC Sent from my Nexus 7 using Tapatalk |
#317 |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
drove 3 years..45,000km...battery died at 35,000km...exterior is wearing out such as black plastic trims, wipers, distorted rubber seals
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
#318 |
![]() Drives: yaris Join Date: Aug 2011
2004 Toyota Yaris 5door Hatchback 1.0 (65hp)
150,000 km (94000 miles) Some electrical problems like the dome light won't turn on, front windshield wiper liquid pump isn't getting electricity. The headlights turned ugly yellow so I changed them, The little engine that could is purring like it's still brand new. |
#319 |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
2009 3door HB 121000km.............Front brakes when I bought in at 78000km in Jan. 2014. Other the tuning and moding I haven't had a single issue or part to remove, even the battery is the original. Car doesn't come out winters so this year it's getting TLC over the winter months. Front wheel bearings, water pump, replace the battery...
#320 |
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
2015 Manual 5-spd SE, manufactured late 2014 France, purchased late July 2015 Colorado, USA. Currently has a bit over 11k miles on it. Only problem(s) thus far:
- Little plastic fins under front bumper, in front of each wheel installed incorrectly @ factory - dealership corrected under warranty. - Annoying rattle/buzz in drivers-side side air vent on choppy roads or bumps - dealership corrected under warranty. So far, that's it. Fingers crossed. ![]() - |
#321 |
El Huevo
Drives: 2007 Liftback Join Date: Aug 2006
'07 LB
315K miles -lots of TIRES! :) -alternator at about 260k -Spark plugs (3 sets) -brake and transmission fluid 240k -Radiator fan 230k -battery (2) currently needs new brake pads and fuel system needs to be cleaned. Overall this car is great, looking to get a newer model to replace this bad boy.
#322 |
![]() Drives: Yaris 1.5 S-Limited Join Date: Jul 2016
Yaris 2010 AT
60k The current problem I'm facing is if it idles in drive and AC on the rpm drops to 500 some times below end up causing a vibration (twice the engine shutdown) Overall this car is awesome. But can any body help with this problem? |
#323 |
A little over 66k miles in my '07 lift-back and I just had to replace the alternator. Mechanic said it was barely making enough power to run the car. Nine years old and all I've had to replace is the water pump, driver's side axle seal and now the alternator.
Best $12,500 I've ever spent lol! |
| excessive sulfur odor on 2007 model year Yaris | tomjasz | General Yaris / Vitz Discussion | 121 | 03-13-2010 06:49 PM |
| TSB's | WD-40 | General Yaris / Vitz Discussion | 27 | 06-06-2007 01:11 AM |
