#127 |
![]() Drives: 2002 Vitz RS Join Date: May 2015
Bumping this for a thanks to Scott, searched on how to jump pins on OBDII port and saw this thread with many others where your knowledge has been very helpful. Kudos to you man!
#128 |
Drives: Toyota camry Join Date: Aug 2016
Listen this is an easy fix , their is a sensor located under the passenger seat . It has two harness clips . Disconnect your battery completely remove the sensor out from under the seat and replace it with one feom your local junkyard . Install and reconnect battery . Problem solved. It took me 10 minutes of my life and saved me a shiv load of money . This is all your Yaris desires don't get tricked into paying for non broken parts . Trust me . Just do what I say and it will work 110 percent . Your welcome
#129 | |
Brilliant first post![]() Now how bout you take the time to read the thread and recognize that this is dealing with the steering wheel clock spring which has since been recalled.
| Help! Airbag light issue | Astroman | DIY / Maintenance / Service | 24 | 05-18-2019 12:35 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 08:20 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
