![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
YARIS Clutch Pedal Noise
Hi can someone help
it is coming from inside the car looks a springy noice what i found SYMPTOM The clutch pedal makes a creaking noise when it is pressed. PROBABLE CAUSE The coils of the clutch pedal assist spring are rubbing against each other, or the clutch release fork pivot bolt is dry. CORRECTIVE ACTION Determine the cause of the noise, then replace the clutch pedal assist spring, or lubricate the clutch release fork pivot bolt. Can someone advise where is clutch release fork pivot bolt. and how can I lubricate this. |
Sorted
Just under the clutch pedal where it links with the main cylinder I spray in the hole with white grease. All quite now thanks |
![]() ![]() Drives: VERSO S Join Date: Jul 2021
yes
| HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. | trini_per4mance | DIY / Maintenance / Service | 42 | 03-27-2017 03:59 AM |
| Squeaky Clutch Pedal? | Kaotic Lazagna | DIY / Maintenance / Service | 43 | 05-29-2016 01:15 PM |
| **SAFETY RECALL!! 06-07 YARIS HB & SEDANS** | slvryaris | DIY / Maintenance / Service | 83 | 09-30-2012 12:25 PM |
