Old 10-02-2016, 09:31 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
The ARtrackbox build
Hi guys, I want to share the information necessary to install a LSD and/or the 4.3 final drive gear into the C50 transmission. Here is the list of parts needed:
1) Limited Slip Differential of your choice
2) New differential bearings
3) Both axle seals
4) 2004 scion Xb output shaft
5) 2004 scion Xb ring gear
6) Control shaft cover gasket
7) 1 or 2 differential shims
Measurements and inspection info here:
http://www.armstrongfamilyblog.com/armstrong-racing
Test drive video after install:
http://youtu.be/i0a5RxkqWck
ArmstrongRacing is offline   Reply With Quote
Old 10-02-2016, 09:44 PM   #2
ArmstrongRacing
Data doesn't lie
Comparison of stock open differential(left) and the Cusco Type-RS LSD(right), the shims and washers are in front of the differentials
Old 10-02-2016, 09:51 PM   #3
ArmstrongRacing
Data doesn't lie
Comparison of the Yaris 3.7 final drive output shaft(left) and the Xb 4.3 final drive output shaft(right)
Old 10-02-2016, 11:36 PM   #4
Sexypartytime
Old 10-03-2016, 03:08 AM   #5
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
awesome stuff as always!
and ooh, m12 impact wrench. Milwaukee fan boy here, love the m12 fuel impact wrench. easily took off the crankshaft pulley bolt, and lug nuts of course.
Check out my Build thread:
c50, diy, final drive, lsd, transmission
budget B Spec rally build slowly coming along 07dirtyaris Tracking, Racing, Auto-X Forum 8 08-15-2016 05:21 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 11:56 AM
Turbo build - stage 1:D abstractmethod Forced Induction Forum 21 03-13-2014 09:04 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-16-2013 12:44 AM
