![]() Drives: Yaris XPF9(A) D-4D 2008 Join Date: Oct 2016
[SOLVED] XPF9(A) D-4D 2008 Fuel indication stuck
Specifications:
Toyota yaris xp9f (a) Engine: Diesel d-4d 1'364cc 90bhp Tank: 42 litters capacity Error: Fuel gauge is propably stuck Explanation: Well i filled the car with diesel yesterday and everything was fine! So i did 110km and I must say that I pressed the gas much more than usual to 140km/h so as I expected my l/100km hit at 5.3 And of course I lost 1 out of 8 lines of fuel... pretty normal. anyway because i don't like the 5.3 number... i decided to fill up again and reset it and so I did. And for my surprise the fuel gauge was still at 7 out of 8... anyway I tried filling it to the maximum "be able to see diesel in the pipe" but still 7/8. Can anyone explain why and how to fix it? Last edited by Coldhammer; 10-07-2016 at 12:37 AM. Reason: solved |
Before you hop all over a possible issue, run the thing for a while and see if it eventually works itself out. You're a bit quick to be calling a problem. If after several hundred kms of driving and a subsequent re-fill the gauge is still showing 7/8 then I'd say there is an issue to address.
And you are right! I did as you said and eventually the 8th square appeared! Thank god... thank you very much!
Sent from my SM-J320F using Tapatalk |
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 327 | 01-02-2026 11:44 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Low fuel light | falkor_99 | General Yaris / Vitz Discussion | 35 | 08-24-2007 03:20 PM |
| Fuel Level Gauge Stuck ? - 2007 Yaris Sedan | kaboom | New YARIS Purchase Forum | 9 | 05-15-2007 02:58 AM |
