Drives: Yaris 2015 Join Date: Oct 2016
Trouble in locating "Tach Wire"
Please assist into locating Tech Wire.
I am installing remote starter on my Yaris 2015. Cross wiring chart says, "wire (RDA); connector (D143 White 30); pin 16; wire color (Pink); polarity (DATA); located at (Body ECU next to dash fuse box)" Is this called Tach as well or something else. Remote error code is referring to "Tach sensing issue". Thanks. |
It's a black wire on the OBD connector. I forget if there's more than one but I think its in the middle somewhere.
Tachometer OBDII multimeter frequency revolutions per minute RPM
There's threads and pictures here showing the RPM input on one of the 4 end sockets of the 2-row OBDII connector. #9? I'm getting good two pulse/rev input there for the frequency setting on a multimeter tucked standing up into the little pull-bin next to the drivers window...multiply by 30 for RPM.
| Trouble Code P2121 | 1nz | DIY / Maintenance / Service | 9 | 09-02-2024 08:59 AM |
| 2010 Yaris Sedan - TROUBLE W/ TROUBLE CODES | Iceman6969 | DIY / Maintenance / Service | 4 | 07-25-2014 09:35 AM |
| Trouble finding correct mirror glass | Daz... | DIY / Maintenance / Service | 0 | 11-26-2011 11:03 AM |
| Alternator Trouble | butter | DIY / Maintenance / Service | 1 | 08-10-2010 04:39 PM |
| Trouble locating tach wire-Help!! | GreenSpeed | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 08-03-2009 12:59 PM |
