Old 03-20-2015, 12:42 AM   #19
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
I think if you changed to 1zz injectors o 4psi, you should be fine. Going to 1zz gave me a -15% LTFT throughout closed loop, so I'm interpreting that means it's putting out +15% more fuel.
Looks like i did this run 4psi, 0 fuel, but pulled ignition timing by -4 degrees
taKuto is offline   Reply With Quote
Old 03-20-2015, 07:48 AM   #20
Changing the injectors will help until the system "learns" that it has extra fuel and trims it out. That only takes about a day of driving to happen.
Old 03-20-2015, 09:20 AM   #21
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Does the factory have enough authority to yank back that much fuel? If so that is awesome. This may speed things along for me until i can afford a patch harness for my AEM
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-20-2015, 09:43 AM   #22
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It's not so much an issue of authority as it is PWM frequency range. In theory it can do PWM from 0% to 100%, but it could be artificially limited to a smaller subset in the control loop. It's likely to be controlled by a PID feedback loop (the same thing that keeps a Segway upright) that targets 14.7 AFR, but the coefficients might be such that they can't cope with dramatically larger injectors. I recall Lt Noogie trying the big grey injectors from a 2.4L engine and it ran too rich almost all the time, constantly throwing CELs.
Old 03-20-2015, 11:11 AM   #23
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
Forgot that you yaris guys have it tougher :P
Old 03-20-2015, 10:26 PM   #24
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
My brain hurts every time I read these posts... I figure, if I read it enough times, it will hit me like a dump truck and that light bulb will finally shine brighter than 1,000 suns
-Derrick-
Old 03-24-2015, 09:10 PM   #25
malibuguy
Obsessed with 1.5L
Explain yourself?
-96 Tercel 4dr
Old 10-27-2016, 08:22 PM   #26
malibuguy
Obsessed with 1.5L
Hoping to find out this in the coming months. I have everything I need. Including a patch harness finally. So if the car does not like things...slap the AEM and have her tuned.
First thing is the clutch...
-96 Tercel 4dr
Old 10-27-2016, 10:39 PM   #27
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I'm not sure on the newer computers but the older ones in the echo will only trim 20% max.
Old 10-28-2016, 08:59 AM   #28
CrankyOldMan
Yes. The Blitz (and my ineptitude at driving a stick) killed the OEM clutch after about 2.5 years. I got a Clutchmasters stage 3 and it's been awesome. It took a week or so to get used to the additional pedal effort, but it's well worth it to be able to hook up and run hard with those extra horses.
Old 10-29-2016, 09:23 PM   #29
malibuguy
Obsessed with 1.5L
I ran a ACT 4puck with a HD cover in my tercel and loved it. Pedel effort went up marginally over stock.
Probaby going to get a full face ACT with a HD cover
-96 Tercel 4dr
Old 10-29-2016, 11:13 PM   #30
KTS
KTS's Avatar
Drives: Vitz RS
Personally i find the the additional pedal effort along with the performance copper clutch disc makes for a more normal feeling experience especially with the dbw throttle when engaging the clutch from a stand still
KTS is offline   Reply With Quote
Old 11-11-2016, 11:48 PM   #31
sickpuppy1
Drives: 2010 Yaris Sedan
Thats because it needs to have the Fletzer bearing reamed,routed and rotated for a free flow press fit.
Old 01-15-2017, 02:44 AM   #32
malibuguy
Obsessed with 1.5L
So attempting low boost is not going to happen.
Found out my wastegate actuator is 7psi...and I not spending money to get a lower one.
Just going to have it tuned at 7psi and leave it.
Its coming together gentleman. I am excited, and hope to have it all done by spring.
I start fabricating the intercooler and charge piping next week
-96 Tercel 4dr
Old 01-15-2017, 02:47 AM   #33
malibuguy
Obsessed with 1.5L
-96 Tercel 4dr
Old 01-15-2017, 09:39 AM   #34
Bluevitz-rs
You can lower the wastegate spring pressure you just have to cut and add to the bottom of the housing. This is mine from the MR2 CT26 turbo. I'm not sure what stock boost was set at but I doubled the length and it now gives me around 6psi of boost. It starts to open at 3.5psi when I bench tested it.
Old 01-15-2017, 12:04 PM   #35
malibuguy
Obsessed with 1.5L
I would think the heat from welding would damage the diaphragm?
-96 Tercel 4dr
Old 01-15-2017, 12:20 PM   #36
KTS
KTS's Avatar
Drives: Vitz RS
I am glad for you that it's coming along. What manifold are you using? And where did you get it and what did it cost? Thank you.
Sent from my SM-G920V using Tapatalk
Grimmspeed Manual Boost Controller For Sale fnkngrv Items for Sale by private party 1 05-05-2014 02:25 PM
