#181 |
![]() Drives: Yaris 2008 Sedan Join Date: Dec 2012
2008 sedan - acquired in late 2009.
Had brake booster issues with it in 2011, but no other problems whatsoever since then other than a squeaky serpentine belt which was replaced last year. ![]() Still looking for the wire harness for the head unit so I connect my OEM aux port I acquired years ago. If you have one, hook me up! I've already been shut down here but I figure it's worth a shot: http://www.yarisworld.com/forums/sho...559#post763559 |
#182 |
![]() Drives: Toyota Yaris SEdan Join Date: Oct 2016
115k.......still kicking ass :P
#183 |
![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
161k on 2009 sedan. Bought the car with 40k on it.
My list of troubles are few. But here they are: 1. Front suspension. The shocks were somehow worn out even though the car only had 40k on it, when we got it. Replaced those. 2. I need to replace a ball joint. 3. Belt started squealing and has been replaced. Still squeals sometimes though... 4. Center console door screws backed out. Took it apart, tightened the screws, and haven't had any trouble with it staying shut since then. 5. Headlights having to be polished out. 6. Some of the rubber door seals letting go and flopping a bit. Siliconed them back down. |
#184 | ||
https://www.youtube.com/watch?v=HRrVMtyIqIY Quote:
Anyway, right on! 161k is a lot of miles. |
#185 |
![]() ![]() Drives: 2008 / 2011 / 2012 Yaris Join Date: Mar 2014
294k
Alternator went out at 289k, only other stuff is multiple drive belts, axle, brakes, etc. Very solid car |
#186 |
Teal Squealer
Car is at 103,700k miles right now. It hit the 100,000 mark back in January.
#187 |
![]() Drives: Toyota Echo 2001 4-door Join Date: Dec 2016
My toyota echo 2001 clocked 473,700 KM's till today. And it's still going strong with original engine :)
#188 |
#189 |
![]() ![]() Drives: 2010 3dr LB Join Date: Sep 2010
Just turned 110,000 miles on my 2010 5 speed HB. Oil and filter changes every 5K with synthetic oil, tires and an air filter are the only maintenance items done. Original brakes and battery still. Bill C
#190 |
Nice
#191 |
![]() Drives: 2007 Toyota Yaris MT LB 2-door Join Date: Aug 2011
121,000 miles. 2007. Love the Yaris!
#192 |
![]() Drives: 2007 THREE DOOR 5 SPEED Join Date: Aug 2009
@198xxx
replaced A/C compressor and associated items after hearing a warbling noise. In addition to the A/C, it was determined the the water pump needed replacing. Still on the original brake pads. Haven't been on the forum in a while, no need to, lol! I think I might buy the "egg" some weathertech floor mats for Christmas. That, or a headlight polishing kit. |
#193 |
![]() ![]() Drives: Yaris HB Join Date: Dec 2014
82,xxx miles 2008
Enviado desde mi SM-G920I mediante Tapatalk
VELMAX member. |
#194 |
Drives: Yaris Sedan 08 Join Date: Jan 2017
100+ mileage
Bought my Yaris sedan in 2008 and so far at 135k miles I have had zero issues that doesn't involve the usual maintenance. Biggest necessity so far was changing the brakes. I also have a Rockford Fosgate amplifier and my second subwoofer and still have its OEM battery.
#195 |
![]() ![]() Drives: 2010 Blazing Blue 3 Door LB Join Date: Dec 2013
I'm over 135000 with all the driving I do for work. The only things ive replaced is the battery about 6 months ago. When I got the car it was already 3 years old and my stereo system probably didn't help extend its life. Also the front rotors and pads had to be replaced on my last inspection, they had over 110,000 miles. Other then that just your usual tires, spark plugs, changed the brake fluid, still need to flush the coolant. Car has been absolutely flawless except for the day the battery just quit on me, luckily it was parked in my garage and didn't leave me stranded on the side of the road. I'll probably replace the asscessory belt this year just for piece of mind.
15' - Crosstrek Hybrid ~ Plasma 10' - Yaris 3 Dr LB ~ The Boom Box 06' - RSX Type S ~ H.S. Dream Car 95' - Delsol VTEC ~ The Racecar 12' - Burgman 400 ~ Garage Queen 09' - Agility 125 ~ 80mpg Daily Rider 09' - Metropolitan ~ Weee 14' - Ecosmart Metro ~ Razor |
#196 |
At 173k km now. Only things replaced so far are the battery and water pump.
This summer I'll be replacing rotors and drums and upgrading front pads. Rotor and drums are rusted to help so the new one will get a coating of paint. The puck bushings on my control arms are starting to have small cracks in them and are due to be changed. I'll be upgrading to whiteline control arm bushings this summer.
#197 |
![]() ![]() ![]() Drives: yaris 2009 Join Date: Nov 2014
105.000 2009 100hp 5door hoho
Sent from my iPhone using Tapatalk |
#198 |
![]() Drives: 2008 Hatch Join Date: Apr 2017
175,9xx on my '08 3 door 5 speed. Rear ABS sensors right after warranty ($1000, grrr), Replaced water pump at 95k. The dealer was going to replace the timing belt on schedule, but when they opened it up, there was a chain! They put in the water pump just because, and sent me on my way. Mostly 40 mpg. Solid little car, but I miss my '94 Geo Metro 1 liter 5 speed...50 mpg...
| Mid-West Chapter Micro Image Car Club | lilredrocket | Southwest | 10 | 10-05-2009 02:06 PM |
| 30,000 mile service: Dealership or non-dealership? | EstherK | DIY / Maintenance / Service | 1 | 11-12-2008 01:40 PM |
| 11/02/08 Metro Auto Squad 1st Annual Car Show (my car club) | Jerkratt | NY / NJ/ CT / PA | 14 | 10-26-2008 06:51 PM |
| Japanese Mix Club Los Invitamos!!! | TunTun_yariS[PR] | Caribbean | 0 | 12-12-2006 01:03 PM |
| Buddy Club Wheels | BulletProofAuto | Sponsors Classifieds Area | 8 | 10-19-2006 07:55 PM |
