Old 11-13-2016, 11:21 PM   #1
Stustu07
Drives: 1990 Mustang
Smile 175/65R14 VS. 175/70R14
Hi guys, my name is Stuart. So I'm no stranger to forums, I did some searching and didn't come up with anything that directly answered my questions. I'm asking these questions on behalf of my girlfriend. So she has a 2007 manual 4-door Hatch (Canadian Car), that currently has 175/65R14's on the car. I wanted to know how much of a change would there be on the speedo if she changed to 175/70R14's. She's staying with a 14" steely as these are for winter driving (better in snow compared to 15's), and she wants a nicer ride feel. I know 14's ride nicer than 15's comfort wise (depends the person and other suspension components). The reason I'm asking is because I have really no idea how changing tire sizes effects the Yaris.. I know on my car I have 2 speedo gears, one on the trans and one on the actual speedo; changing tire sizes if not done correctly would cause me to have to change 1 of the 2 gears to get the right reading on the speedo. All help/info is appreciated, thanks!
(Btw I use this site when comparing tire size changes tire size comparing site)
Stustu07 is offline   Reply With Quote
Old 11-13-2016, 11:50 PM   #2
SirDigby
Drives: 2007 yaris 3 door
well....it's an 8.75 mm difference, larger. so....around 2 Kmph faster than displayed speed at 80Kmph (1.5 Mph at 60 Mph)
Old 11-14-2016, 12:01 AM   #3
Stustu07
Alright thanks, I was just trying to figure out how much of a difference it would make on her to mileage count, was hoping it would only make a small change like the site I use says.. Just didn't know if the speedo was flexible on it's readings, meaning I didn't know how precise the speedo reading is with stock tire size.. Have seen here and there that some people have gotten better readings changing tire size, that's why I wanted to know how much of a change in reading would occur. Thanks.
Old 11-14-2016, 01:49 AM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
There is a 3% difference in diameter. You cqn compare the speedometer reading to a GPS to see if there is a difference worth worrying about.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 11-14-2016, 08:59 AM   #5
When the speedo says 100kph you're actually going 103
But if it's anything like my echo hatch, the speedo reads high in the first place
Old 11-14-2016, 12:06 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
The speedo is probably not accurate out of the box.
BTW, 185/70/14's are the same diameter as OEM 185/60/15's.
Old 11-14-2016, 10:17 PM   #7
Stustu07
Alright thanks guys! I'll be testing accuracy with my GPS on Wednesday in her car. Also wasn't OEM in Canada 175/65R14 on the base models? So I'm guessing the speedo's in the 14" and 15" cars are the same (RS vs Base vs LE)?
Old 11-15-2016, 10:33 PM   #8
OEM for 2007 was 175-65-14 in Canada
Old 11-16-2016, 12:30 AM   #9
kimona
kimona's Avatar
Thanks. Yes, I am aware of that. The OP seemed to be concerned that 175/70/14's may be too tall for his car, so I wanted to assure him that they would work since OEM 185/60/15's are the same diameter.
Old 11-16-2016, 07:02 AM   #10
IllusionX
Drives: 07 Yaris Sedan Aero
I run 195/60R15 in the winter, and I really enjoy the 1/2" extra ground clearance I get.
Old 11-17-2016, 01:01 AM   #11
SirDigby
I wouldn't trust a gps. sometimes my gps says i'm moving 3 mph when i'm sitting at a red light...
Old 11-17-2016, 01:16 AM   #12
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Buy a new GPS.
NYC-SE is online now   Reply With Quote
Old 11-18-2016, 09:46 PM   #13
SirDigby
why would I buy a new one? I don't have it to tell me how fast i'm moving, that's not its function...
Old 03-28-2017, 07:03 PM   #14
dogsridewith
Drives: 2007 2-door hatchback
Yokohama IG52c is a tall 175/70R14
By measurement w/ a thin steel tape before inflation, confirmed by actual tire specs provided by TireTrack site, these 175/70R14 Yokohama IceGuard IG52C studless winter tires are 4.3 % taller than the baseline 175/65R14 given by the Tacoma tire link in Post 1. Shown on OEM 5" wide steel rims w/ Tercel centercaps and short valves. Tread width measures 6" between sharp cornered shoulders. Beads were visibly close before installation. Installer asked if I knew these were going to be this tall.
Smooth and quiet and seemingly free-rolling on pavement. Car drove and steered nicely on one slushy snow section of high-crown gravel road w/ a moderate hill (up and down.)
Old 03-28-2017, 10:30 PM   #15
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The other consideration is the visible accuracy of the speedo: parallax from different driver positions will slightly alter the location of the needle over the tick marks, easily causing a few percent error. Oh, and you should be more focused on looking out the windows than your speedo.
Old 03-29-2017, 08:53 AM   #16
dogsridewith
Mind of Toyota speedometer error factory tire size
Do we know for sure that Toyota didn't somehow setup speedometers differently for the nominally 3.4% different height tires they were installing?
Old 03-30-2017, 09:04 AM   #17
Yaris709
Drives: 07 yaris
My speedo on my 07 Sedan was slower with the 175/65r14's. I run 185/70r14 in winter and 195/60r15 summer and those are within 1km/h from speedo to gps
Yaris709 is offline   Reply With Quote
Old 03-30-2017, 10:10 AM   #18
kimona
kimona's Avatar
After replacing the OEM 185/60/15's (23.7" dia.) with 205/50/16's (24.1" dia.), my speedo was dead on!
185/60r15 on steelies VS. 175/65r14 on steelies... baseballfan416 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 07-29-2014 07:18 PM
Dunlop Graspic DS-3 winter 185/60R15 90% left 07yaris_fe Items for Sale by private party 0 05-28-2013 09:31 AM
A Pair of Goodyear Nordic 175/65R14 MUSKOKA800 Canada 4 01-31-2011 02:02 PM
