Old 11-26-2016, 04:39 PM   #1
Pinchlite
Drives: 2007 yaris HB
How much to lower?
Wheels:16x7/4x100mm offset 40
2007 2DR HB.
I was thinking 1.5 drop.
Roads are good in my parts.I kind of have an obsession of missing every bump,manhole cover etc for some reason already on stock.Mind you I have always done this with all of my cars.
Old 11-26-2016, 05:15 PM   #2
SirDigby
Drives: 2007 yaris 3 door
1.5 inches in the rear is pretty standard. you can go a lot more if you want to. :)
Old 11-26-2016, 05:21 PM   #3
Pinchlite
Lowering
I am going the cheapest route.I am just getting other springs.I dont drive aggressivly at all but just want less wheel well showing with the wheel specs I posted
Tire BTW are 205/45R16 Comp TA 2
Here is springs I had in mind.
http://www.odparts.ca/catalog/ksport...32-p-7026.html
Old 11-27-2016, 12:27 AM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
2007 2DR HB.
Tein springs with kyb struts plus TRD swaybar 2 inch drop works perfectly on my Yaris.
Sent from my HTC One A9 using Tapatalk
Old 11-27-2016, 08:24 AM   #5
Pinchlite
lowering
Well I already have rims and tires in the dimensions that I mentioned earlier.
I can only afford springs.
Basic question would this work without being a problem?
1 3/4'' drop
P.S
I may be able to squeeze in the sway bar into my budget if it helps?
Old 11-27-2016, 11:22 AM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
1 3/4'' drop
P.S
Well I would save ur money cos if ur car has high km its going to need struts and might as well save the labor costs and do it once right.
Old 11-27-2016, 01:07 PM   #7
Pinchlite
The struts are 2 1/2 years old.I have receipts and my mechanic said they are not original.
If struts having high kilometers on them being the deciding factor then I will go ahead and do the springs.
Thanks for reply back.
Old 11-27-2016, 01:11 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Go for it, takes about 2.5 hrs for the whole job to lower ur car than u will need alignment done to fix toe set.
Old 11-27-2016, 01:14 PM   #9
Pinchlite
springs
I will let a shop do it for me.
I do have the tools besides the spring tensioner which I could rent but I dont have proper place to do the job.
I will ask my regular mechanis what he would charge.
Old 11-27-2016, 05:16 PM   #10
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Like Exiwolfman, I'm on the Tein S Tech springs, but I'm still on factory shocks/struts. Loving every second of it.
On Instagram
On Wheelwell
Old 11-27-2016, 05:21 PM   #11
Pinchlite
springs
Well those are 1.5 and are almost double the cost of what I linked.$358.00 CAD.
Would 1.5 even make a visually noticable difference?
If the ones I linked are no good then I will probaly hold off putting the new rims on this summer.
Old 11-27-2016, 05:35 PM   #12
SirDigby
you get what you pay for. Tein's are almost the best suspension components you can get for under $4000.
1.5 makes a huge difference in visual appearance.
Old 11-27-2016, 05:37 PM   #13
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
One can find teins at a lower price and ya it's a noticeable difference between 1.5 and 2 inch drop.
Old 11-27-2016, 07:00 PM   #14
Pinchlite
1.5
So 1.5 drop with the wheels and tire sizes I posted/mentioned would look okay.(2 DR HB)
As long as it does not have too much gap then I may go 1.5 and go for the tein spring afterall.If a few things go as planned I can swing it in my budget.
Old 11-27-2016, 07:02 PM   #15
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Well I would go with drop first than wheels with ur wheels I think teins should be fine.
Go low or go home lol
Old 11-27-2016, 07:07 PM   #16
Pinchlite
springs
Thats my plan.I will not be putting on new wheels untill I lower.
I just was not sure 1.5 was enough as I have read many posts that say 1.5 is not even noticable?
Did you see the wheel and tirespecs I posted?
Old 11-27-2016, 07:08 PM   #17
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Well I'm on 195 55 15s and on teins so compare that size to urs and I'm 42 offset.
Old 11-27-2016, 07:13 PM   #18
Pinchlite
lowering
I already have this bought.
205/45R16 Comp 2
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 04:18 PM
Lower control arm replacement 2005 Echo ? Infinitrium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-27-2012 04:23 PM
Should I lower the PSI during the Winter? paulyd0021 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-10-2009 11:12 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 07:49 PM
