Old 02-04-2014, 06:13 AM   #199
Originally Posted by xiaoya View Post
I tried the mod today but with no luck. The warning light is still on after I connected brown to white. Please see the attached pic. My yaris is a 2008 one.
Thank you.
That is because you did not follow the instructions. You connected the wrong side of the brown wire to the white wire. You need to cap off the end that comes out of the connector and instead tap the end that heads up to the cluster to the white.
Old 02-04-2014, 10:49 AM   #200
xiaoya
Drives: 2008 Yaris
Oops, I got it totally opposite. My wife is driving the car today, will fix it tomorrow.
Thank you very much CTScott
xiaoya is offline   Reply With Quote
Old 11-11-2014, 05:48 PM   #201
maui
Drives: 2008 Yaris hatchback in white
I was just studying this TPMS sensor solution. Comparing photo #2 the the color coded diagrams, it looks like one just clips the brown wire and splices it to the white one, and that this would be easy using one of those press down splicers, and of course taping off the end of the other brown wire.
Please let me know if this interpretation is correct. Or if anyone has a picture of the completed splice please post.
Since this is reversible it looks like an easy solution.
Thanks,
Maui
maui is offline   Reply With Quote
Old 06-19-2015, 09:34 AM   #202
hatchbackkid82
Drives: .
Will this work if you have a bad TPMS? My light flashes and stays on.
I'd rather disable it all together, stupid shop wants $320 for one sensor
Old 06-19-2015, 06:13 PM   #203
Yes it would make the light go away.
Old 06-22-2015, 11:10 AM   #204
hatchbackkid82
Drives: .
I did this over the weekend when i had my tires replaced. I had them pull the sensors out too. Worked like a charm. Thanks guys
Old 12-04-2016, 04:32 PM   #205
tradergordo
Drives: Yaris (2010, 2007)
I did this fix on a 2010 Yaris and it worked perfectly, so thanks a lot! But now I want to do the same on a 2014 Yaris (4 door hatchback) but I don't see the TPMS ECU behind the glove box. Does anyone know where it is? I couldn't find any free repair manuals online like there are for older models, cheapest one on eBay is $60...
tradergordo is offline   Reply With Quote
Old 12-04-2016, 07:25 PM   #206
There is not a simple solution for 3rd gen (2012+), as the TPMS ECU now sends the info to the cluster via CAN bus message, rather than by a simple single line driving an LED.
The third gens do allow you to easily relearn the TPMS sensors by simply pressing a button, so the simplest solution is to have a second set of sensors in your alternate rims.
Old 12-05-2016, 10:48 AM   #207
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
Is there not a way to short out something at the wheel/sensor end before it gets encoded onto the CAN buss?
This looks like yet another case of unnecessary electronic complexity being put into cars, which means more things to go wrong. I work in the very high tech semiconductor/software industry myself, so I'm not against advances in technology as such, just against technology which causes more problems in the long run.
Sent from my LG G2 with CM13 using Tapatalk
tarkus is offline   Reply With Quote
Old 07-12-2017, 01:57 PM   #208
fj40dave
fj40dave's Avatar
Drives: '08 HB
Just did this mod
Cut the brown, press-splicer brown and white....worked perfect (after I plugged the connector back into the box - duhhhh)....
Thank you - this place rocks!
(I chose to not have the sensor replaced after I heard it bouncing around in the left front tire and would have to pay $60 for a replacement)
fj40dave is offline   Reply With Quote
Old 07-20-2017, 01:21 AM   #209
Juanalexis21
Drives: Yaris sedan 2010
Hello friend, let's see if you can help me! I have a 2010 Yaris sedan and I changed my tin rims for type S, I did not change the TPMS sensors of my original rims but the emergency rubber still has the factory sensor. The type S rings have their original TPMS sensors but the vehicle that had them. How can I configure the new sensors in my vehicle?
I know it's not a blog but I hope I can help. Grateful!!!
Enviado desde mi SM-N910W8 mediante Tapatalk
Juanalexis21 is offline   Reply With Quote
Old 08-10-2017, 12:20 PM   #210
Kawiman
Drives: 2010 hatch
Sorry. I didn't read through the hundreds of posts. Just skimmed through and I didn't see that anyone had done what I did on my "09 Tacoma and '10 Yaris.
I removed the instrument cluster. It's very simple and just placed a double folded portion of electrical taped under the gauge face plastic film. Done.
This way nothing is eliminated if years from now you or the next owner wants the system in use.
It looks like the light was never there.
Kawiman is offline   Reply With Quote
Old 01-04-2020, 05:31 AM   #211
CrimsonEclipse
Drives: .
My apologies for resurrecting an old thread but I am having a problem with my TPMS on a 2011 Yaris.
The problem is, all of the pictures posted were on PhotoBucket and they purged all of their free user pictures.
The only pics lift are of Rick's on post #138.
I can happily try this one but I'd like verification that it worked from someone.
Also, would disabling the TPMS show up in the OBD2 scan?
thanks!
CrimsonEclipse is offline   Reply With Quote
Old 06-26-2021, 06:17 PM   #212
Maui Paul
Drives: Yaris hatch
TPWS issue
You do need to keep the connector plugged in (with those two wires cut) to sucessfully do the mod. If you just unplug the connector, the TPWS light will immediately come on and will stay on until it is plugged back in.
Cutting those two wires fools the Tire Pressure Warning System into thinking that the car is not moving and the engine is not running. The TPWS will not report an error if it doesn't hear from the tire sensors as long as the car is not rolling and the engine is not running.
We have the light on and are happy to just disable the system by cutting the wires. Someone said it only works if no light is on which is not the case here.
Can someone suggest a way to get the idiot light off AND disable the TPWS system please?
Maui Paul is offline   Reply With Quote
Old 08-11-2021, 11:20 AM   #213
mrgodai
Drives: Yaris Seden 2008
post #115 picture on the left will do it
mrgodai is offline   Reply With Quote
Old 01-18-2025, 02:40 PM   #214
apmatzen
apmatzen's Avatar
Drives: Toyota Yaris 2015 1.0VVT-i T2
Does this work on a 2016 Yaris?
Toyota Yaris 1.0VVT-i T2
apmatzen is offline   Reply With Quote
Old 07-14-2025, 04:28 PM   #215
Walsh11
Drives: 2013 Yaris
I have a 2013 Yaris, anyone please tell me how to disable this abomination system lol. thanks
Walsh11 is offline   Reply With Quote
Old 07-15-2025, 07:01 AM   #216
Walsh11
Drives: 2013 Yaris
HELP LOL
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 05:53 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
