#271 | |
![]() ![]() ![]() Drives: MR2 Spyd/Type R/Yaris/Civic Si Join Date: Feb 2007
can you explain a little bit what makes the ECM the limiting factor?
https://www.instagram.com/3cyltrbo/ |
#272 |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
Because we don't have a USDM 3zrfe, I have no service manuals for it either to verify wiring compatibility
#273 |
Data doesn't lie
*With the help of other YW members, I have started a collection of 2ZRFE parts to make everyones swap a little easier, just contact me for details!*
#274 |
![]() Drives: 2009 Scion xb Join Date: Oct 2012
Ok. This is a hijack but guys I am stuck! I have a Scion xD 5 speed and the transmission has given up the ghost. Replacement transmissions are incredibly expensive or impossible to source. I have been chatting with a fella that said that the Yaris is bolt in although it is a little lighter duty and requires the Yaris axles that it should otherwise fit without modification. I'm in a real right here and really need your expertise. Please forgive the hijack. It just looks like a good active thread.
Thanks in advance. |
#275 | |
2ZR swap. DO IT! Ask how!
That said... Do you know what is specifically wrong with it? The only difference internally that I'm aware of is the differential and ring gear. If it's the synchros or one of the gear sets, you can (I'm 99% sure) use a Yaris as a donor for parts. If you swap the whole gearbox, you will indeed have to use Yaris axles, but that puts you in the bind of having to swap hubs and brakes--not something for the timid. You might be able to use the inboard stubs from the Yaris with the xD shafts, but that's uncharted territory. |
#276 |
Data doesn't lie
Honestly I would just fix your trans, these gearboxes are simple. (Heading over to thread to comment)
#277 |
Data doesn't lie
#278 |
Data doesn't lie
UPDATE:
Our first autocross test day was a success, the car is so quick now!! https://youtu.be/eniW1ZNv20k |
#279 |
The production value / editing in your vids has consistently improved; nice job.
#280 |
Are you running as E Prep, or is that for SCCA club racing with E Production?
#281 |
Data doesn't lie
EP Because the car has no interior. I regret removing it but after 10 years of daily driving with kids, it was pretty trashed. Plus with it gone the cage install will be easier
#282 |
I can't find the part in EP that allows engine replacement. =P
#283 |
Data doesn't lie
Yeah....I just got a message about that on FB.....even though I asked several people I guess it's still not correct....but it's arguable because it's a Toyota engine....If I must put it to XP that's fine too.
#284 |
I think it would just be E Mod. /iono
#285 |
Data doesn't lie
Ok. So after discussing the classes with other seasoned veterans, We are going with XP
#286 |
#287 |
#288 | |
| unusual engine swap | CoryM | Performance Modifications | 26 | 10-09-2015 12:17 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| engine swap | djhuddy2442 | Performance Modifications | 6 | 04-11-2013 01:05 AM |
| Boost Gets U Laid eh? Count me In | yaris2010RS | Forced Induction Forum | 128 | 02-02-2013 04:57 PM |
| Scion/Yaris engine swap | mrrock | Performance Modifications | 1 | 03-02-2011 06:56 PM |
