Old 01-27-2015, 01:36 PM   #307
markcuban
universal 4 bolt pattern
I'm looking at a set of ICW racing rims from a craigslist ad the are 15" universal 4 lug pattern. Will they fit my 07 Yaris?
markcuban is offline   Reply With Quote
Old 01-27-2015, 02:29 PM   #308
Ben_
Drives: 2010 Yaris Hatch
The easiest way to check is to go down there and try them. If they bolt upa and don't scrape the brakes or the fender/body you are good
Ben_ is offline   Reply With Quote
Old 03-05-2015, 09:17 AM   #309
MJZ
Drives: 2008 Yaris 3 Door Manual
Anyone running 195/65R15 ET 38 ?
The one tire website that allows you to do a compareson between the 2 tires sizes reports that I should have no issues outside of the tires being 16mm larger overall, which with a stock suspension *SHOULD* be fine... anyone have any inputs or personal experience with this size? Got a 2008 2door HB.
MJZ is offline   Reply With Quote
Old 03-05-2015, 09:47 AM   #310
^ There will be no issues.
Old 03-05-2015, 09:58 AM   #311
MJZ
Coolness! Thanks man!
Old 05-30-2015, 08:39 PM   #312
mouvoi
Drives: toyota echo 05 hatch
Hey Guys !
I have a question about tire rubing on my toyota echo hatch 05
I have 205/45r17 rims. I bought those rims used and the owner didnt know the offset....
I am presently running them on stock suspension , I rarely rub in front when I am maxed out.
my question is if I install Tein S.tech springs will it rub ? the springs are 1.7 inch drop in front and back .
Thanks guys
mouvoi is offline   Reply With Quote
Old 07-09-2015, 05:17 PM   #313
Ben_
Look at the room you have in your fenders. If you have 3" clearance I'd say go for it. On a one off setup there is no "yes or no" since probably nobody has ran that tire size those rims those springs and whatever alignment you have. The only sure fire way to find out is to buy them and try it on. Other than that get out your measuring tape. You will need clearance for suspension travel
Old 02-18-2016, 05:17 PM   #314
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Figured I would post a link to my favorite tire size calculator. I use it all the time at work. It lets you compare the measurements of two given size tires. Really great tool. The wheel one that what posted in this thread is awesome also.
Tire size Calc
brushforhire is offline   Reply With Quote
Old 04-29-2016, 07:59 PM   #315
texascolt45
Drives: 2015 yaris
new shoes
205/50-15 toyo's.Konig Helium 15X6.5 bronze.
texascolt45 is offline   Reply With Quote
Old 10-31-2016, 06:58 PM   #316
curtishunter
curtishunter's Avatar
Drives: 2008 Toyota Yaris Hatchback
I didn't find an answer for my question...
What is the OEM size for the spare wheel on a 2008 Yaris 2dr hatchback with 15" factory steel wheels?
I bought the car for my wife but the spare wheel is missing.
I've asked the local Toyota dealership and they wanted to sell me a full size wheel and I told them, that won't fit in the trunk...
Then they sent me an email with these numbers: T125/70D15
I went to the local junk yard (I don't want to spend 180USD on the rim +155USD tire + tax) and find one for 20USD.
When my wife came home I tried the spare next to the full size wheel and it was much smaller! (The diameter). Is it normal? Or that car needs the T125/70D16?
Help me please! I am so confused...
curtishunter is offline   Reply With Quote
Old 10-31-2016, 08:11 PM   #317
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
T125/70D15 is correct.
Yes, it is smaller and looks even smaller when on the car. It is normal.
Hence the words on the spare "Temporary Use Only".
It's only meant to take you to the nearest town to fix your flat tire.
Old 10-31-2016, 09:14 PM   #318
curtishunter
"yarisugi"
Thank you so much. And thanks for the picture. :)
I was an id1ot! I found all the info on the driver side door frame....
Old 11-29-2016, 02:11 PM   #319
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
Official YARIS Wheel & Tire Guide
Winter tires now ...
wheels are Sparco Drift 6.5x15 et37 with Nokian Hakkapeliitta R2 studless 185/55-15 !
KimmoKekki is offline   Reply With Quote
Old 12-23-2016, 03:20 PM   #320
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
Hey Kimmo how wide I can go with a 16" wheels I just want the rim to be flush with the fender
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 12-23-2016, 03:28 PM   #321
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Depends on offset. You can go up to 8" wide with a +40 offset but most manufacturers don't make them in those sizes with a high offset.
First - what diameter do you desire? 15", 16", 17", 32"?
Old 12-23-2016, 03:29 PM   #322
Yaris874
Yaris874's Avatar
I saw on ebay 16x8
Old 12-23-2016, 04:31 PM   #323
KimmoKekki
KimmoKekki's Avatar
I don't know !
Old 12-23-2016, 04:37 PM   #324
Yaris874
Yaris874's Avatar
32"
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
