#19 |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
The Whiteline bolts sure look like reboxed SPC bolts. Funny that they have a different range spec. Cam bolts are intended to be put in the top holes. As mentioned, just put the one pair in and go from there. Most people won't need more than that.
#20 |
![]() ![]() ![]() Drives: 07 yaris hatchback Join Date: Dec 2016
Should be the bottom
Sent from my SM-G935T using Tapatalk |
#21 |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
I certainly hope these bolts are at least made from a better material than OEM. I guess it might be ok to run a bolt like this for regular road driving, but on a track under heavy loading......lets just say I'd be a little more concerned about that crash bolt sheering off due to less material.
Then again, my concern could be totally unfounded. At any rate, definitly go spend some extra cash to get the good stuff, and avoid cheap knock-offs.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
#22 |
They always specify the top. It gives better angles, and may have less force on it.
http://www.spcalignment.com/instruct...40-INS_WEB.pdf Invader166: Cam bolts hold up fine on track and at autoX (where loading is typically higher). Personally I'm not comfortable that two bolts are safe (and they do specify to only use one set), but I believe Jason runs two in his racecars with no issues. Cheers. |
#23 |
Pumpman
I see...thank you for providing more info Cory.
| coilover questions | why? | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 05-11-2012 02:58 PM |
| Finishing my suspension | ChinoCharles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-15-2011 10:26 PM |
| NSW Proposed Suspension Restrictions | Bella | Australia | 0 | 09-22-2010 02:51 AM |
| Brand New Suspension Questions... | silaypalmer13 | DIY / Maintenance / Service | 5 | 03-13-2009 02:26 PM |
| A few questions about suspension, tires, and brakes. | supmet | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 02-02-2009 05:55 PM |
