Old 01-08-2017, 05:42 PM   #1
1L2004UK
Drives: 1L Yaris 2004
2004 Door hinge dropped, TYIA.
Hi all,
I have a 2004 2 door Yaris and love it, just recently the passenger door has become hard to open and if doing so slowly I can see the door drop a little, I am guessing the hinge has worn, is this a common fault and something I could fix myself?
TYIA, Alan.
1L2004UK is offline   Reply With Quote
Old 01-08-2017, 06:00 PM   #2
1L2004UK
Sorry if I have posted in the wrong place (I am new to the site), please re-direct me if needed.
TYIA, Alan.
Old 01-08-2017, 07:14 PM   #3
bronsin
bronsin's Avatar
If the hinge is bolted...yes you can just replace it.
Welded...not sure.
Old 01-08-2017, 11:38 PM   #4
KimmoKekki
KimmoKekki's Avatar
Drives: Yaris T-Sport
Welded Toyota door hinge ... haven't ever seen !
Not common issue i would say
KimmoKekki is offline   Reply With Quote
Old 01-09-2017, 12:13 PM   #5
1L2004UK
The hinges are not welded, however the side of the hinge that goes to the body of the car are inside the wing so access seems impossible.
I have bought a Haynes workshop manual but that just says support the door and unbolt it.
Any advice would be great.
Old 01-09-2017, 12:29 PM   #6
KimmoKekki
KimmoKekki's Avatar
For first aid !
Install between door and lower hinge washers .. just normal 8mm washers !
Loose both bolts and add 1 at a time ... then just tighten up
Old 01-09-2017, 02:39 PM   #7
1L2004UK
Kimmo you are a genius! That is a brilliant idea!
Thanks dude. :)
Old 01-09-2017, 02:41 PM   #8
KimmoKekki
KimmoKekki's Avatar
That's how we have fixed those from older Starlets and Corollas
Old 01-09-2017, 06:51 PM   #9
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Lubrication is key to survival.
Dropped battdry hook inside engine bay M4One General Yaris / Vitz Discussion 8 11-19-2015 08:03 PM
FS: 2004 Toyota Echo RS Hatchback ldd Cars for Sale by private party 0 11-15-2015 10:04 PM
toyota vitz 2004 Fraz In Car Entertainment + Electronics (audio / video / alarm) 3 12-18-2006 03:31 AM
