Old 01-12-2017, 10:53 AM   #1
Yaris709
Drives: 07 yaris
Led headlights?
Just wondering if the newer type led's with the heat sink on back will work in the h4 yaris headlights? Since the h4's have that rubber seal around the back of the bulb. And a good bright reputable led if anyone knows what brand is good!
Yaris709 is offline   Reply With Quote
Old 01-12-2017, 11:12 AM   #2
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
I got this one on ebay super bright
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 01-12-2017, 11:47 AM   #3
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
No problems fitting it into the Yaris' cramped space?
Sent from my LG G2 with CM13 using Tapatalk
tarkus is offline   Reply With Quote
Old 01-12-2017, 11:49 AM   #4
Yaris874
Yaris874's Avatar
Wat year my 07 H.B FIT GOOD
Old 01-13-2017, 10:56 AM   #5
Yaris709
Drives: 07 yaris
What's the name of these listed as on ebay?
Old 01-13-2017, 11:10 AM   #6
Yaris874
Yaris874's Avatar
Old 01-13-2017, 12:51 PM   #7
i had them in my echo...no issues. H4's in my wifes old Kia Soul, too....no issues
www.facebook.com/kitchenerHID
Old 01-13-2017, 02:39 PM   #8
Yaris709
Drives: 07 yaris
How much brighter than the stock halogens were they?
Old 01-13-2017, 02:40 PM   #9
Yaris874
Yaris874's Avatar
I take a picture tonight and post it
Old 01-13-2017, 04:22 PM   #10
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Even more important that brightness - how do these affect the light pattern? Most LED replacements I have seen for other globes have the LEDs covering a different area to the original globe filaments. This can significantly change the pattern of light output. Worst possibility with the headlights is to dazzle other drivers and possibly cause an accident.
I look forward to seeing the photos of the light output.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 01-13-2017, 06:13 PM   #11
Yaris874
Yaris874's Avatar
Low
High
High
Low
Low
Low
High
Low
High
I hope this works
Old 01-13-2017, 08:31 PM   #12
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Thanks. Great photos. I will have to get some of these and try them.
Old 01-13-2017, 08:52 PM   #13
tmontague
tmontague's Avatar
I'd love to see how they look from an incoming direction. Up close they seem like they have a decent cut off but from any kind of distance they shed a lot of bright light up top even on low beams.
I'm all for brighter lights but in almost every case I've seen anything brighter than oem needs a projector or else they blind other drivers and tell "I do half assed mods to look good but screw other drivers"
They may actually not be bad at all tough to tell though without seeing them in person. They are much better than oem.
So many cars in my area throw in led's or hid's and skip on projectors to "save money" and they make it impossible to see.
Old 01-14-2017, 01:15 AM   #14
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
+1
Old 01-14-2017, 01:01 PM   #15
tarkus
tarkus's Avatar
Headlamp bulbs are a PITA to replace in a Yaris, and you basically have to take the bumper/cowl partly off. So I would like to only use LED replacements from now on, but just with regular brightness. Is that not possible?
Old 01-14-2017, 01:23 PM   #16
kimona
kimona's Avatar
Drives: 2014 White VITZ
+1
Old 01-14-2017, 08:07 PM   #17
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I totally agree with this. I'm currently using these LED bulbs, which are simmilar:(http://www.hidvisioncanada.ca/produc...ed-driver.html) and let me tell you, it's darn near impossible to get a proper cut-off with them.
Check out the picture below of how it looks onwards. Note: Driver side needs allignment. Any DIY guides on how to do this?
This thing is, reflector housings were never designed for brighter output. The cut-off will always be washy. The same thing will happen if you change your OEM bulbs with brighter halogen bulbs.
If you trully want a poper cut-off, then a projector retrofit is the only real way to go.
Old 01-15-2017, 01:24 AM   #18
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Do a proper HID projector retrofit. Anything other then a HALOGEN bulb in a housing designed around a HALOGEN filament and the way it produces light is going to be a downgrade and reduces safety for you and other motorist. You basically paying to downgrade the car.
My favorite halogen bulb that I ran in my sedan prior to HID projectors was the Osram Nightbreaker. Powerbulbs.com sells em for a great price and I absolutely loved them.
However nothing beats properly engineered HID projectors with excellent cut off and more even light beam
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Having a few very very odd issues after LED conversion Astroman In Car Entertainment + Electronics (audio / video / alarm) 8 08-03-2014 05:53 AM
Does anyone realize yarisworld is getting 'less busy'? caineroad General Yaris / Vitz Discussion 84 11-05-2013 12:19 AM
FREE Projector Headlights OR LED Tails in exchange for appearance in how-to video V70R_Blackbrick California 4 10-13-2013 10:57 PM
Yari gets a sway bar and a rim change (again) D&D Photo-Video-Media Gallery 8 09-16-2013 01:10 AM
Cruise Control kicking itself out GTBaker Third Gen Yaris General Discussion 9 09-05-2013 09:39 PM
