![]() ![]() Drives: yaris advance Join Date: Jan 2009
BACK UP LIGHTS PROBLEMS
Hello guys, I just notice that my BACK UP lights are not working properly, it does lights up when I put the gear on reverse, but some times turns off, is like something with the switch is loose.
Where is the switch for it? ![]() My light of temperatura cluster also for the a/c when off some time ago, I installed a new bulb but nothing happend, si it has to be something else, please advise. |
What year is Yaris and is it an automatic or manual transmission?
2008, sedan, manual
OK. The back-up light switch is located on the top of the tranny. You will need to move the battery out of the way to get at it.
To do a quick and easy test to see if it is actually the problem, you could jump the red wire in pin 3 of connector CA1 to a +12V power source. If the lights come on when you do that, then you know that either the back-up switch is bad or its connector is corroded. CA1 - MT Back-up Switch.jpg
Thanks a lot, I will check on it!
Yes the lights are ok, so it's got to be the switch or the plug, where do I find them?
#7 | |
#8 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
![]() ![]() Drives: 2007 Yaris HB Join Date: Mar 2012
Yes, check out the wires coming out of the switch, a mouse ate through one of my backup light switch wires!!!!!!!!
Mike |
Well it's nice to know where it is, and yeap, it's going to be a pain to get to it, I'll keep you posted.
Thanks a lot! |
#11 | |
![]() ![]() Drives: 07 Yaris Join Date: Sep 2012
What exactly is the bottom end of the arrow pointing to? I can't quite tell from the diagram. Also should this be done with the car on or off, or in accessory mode? Thanks |
#12 | |
| Question about lights | kaymm | General Yaris / Vitz Discussion | 4 | 04-20-2020 10:10 PM |
| No parking lights | ryufrank | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-06-2013 10:28 AM |
| Clazzio MicroImage problems please help | boggydee | Cosmetic Modifications (Exterior/Interior) | 1 | 08-24-2012 05:16 AM |
| LED tail lights installed | Cutie Pie #2 | Cosmetic Modifications (Exterior/Interior) | 10 | 08-21-2012 12:25 AM |
| JUST GOT MY JDM TAIL LIGHTS!!!!! | falkor_99 | Cosmetic Modifications (Exterior/Interior) | 12 | 10-01-2007 12:25 PM |
